Originally Posted by
pari
Hi Jim,
So I've been looking at the Planet website. What components did you use to upgrade your machine? I notice there is n Ethernet drive, did you use that or are you using USB. I'd like to here how you went about the upgrade, and the process for swapping out the old components. for example did you keep the old motor drivers, power supply etc. Have you added limit switches, E-stop or some kind of pendant control?
If I thought I could just buy the USB controller and put in in my machine, and that would do it I would probably do it, but I suspect it's a bit more complicated than that.
