- Need Help!- Tool change park position Multicam 5000
Whenever I select a tool outside the ATC range (tool 13 and up) the router travels to the hard home position before prompting a manual tool change. However, for me the hard home is on the opposite side of the table from my work station. I don't want to move the hard home. Is there any way to change the manual tool change position?
Thanks for reading this
Re: Tool change park position Multicam 5000
THIS LIST I AM ABOUT TO POST, CAN AND WILL CAUSE HOVAC WITH YOUR MACHINE. DO NOT CHANGE PARAMETERS RANDOMLY.
The parameter you need to change is 270 and 271, this will change the location of where the manual tool change position is located.
- You may not post replies
- You may not edit your posts
Forum Rules
