This may help, MC perimeters for creating PP's.
MultiCam - Support - M & G Codes
Neal
Hello Everyone,
I am making changes to a post processor for multicam routers. I have a few questions, can you help.
1) Are the feed rate setups different from one mulitcam router to the next?
A. inches per min
B. inches per second
C. inches per feet
What is common on this controller and can they be changed from one to the other and if so how is that done.
2) I would like to comment out tool information so when you are looking at a program you know what tools are being used. Does the multicam support comments and if so how.
upload picture
Code:M90 G98 P133 D1 G90 G70 G75 G97 S12000 G00 T1 G00 X5.5 Y0.625 M12 G00 Z-0.1 G01 Z0 F0.5 G01 Z0.25 G01 Y3.375 Z0.25 F1. G03 X5.375 Y3.5 I5.375 J3.375 G01 Y0.5 Z0.25 G01 X5.25 Z0.25 G01 Y3.5 Z0.25 G01 X5.125 Z0.25 G01 Y0.5 Z0.25 G01 X5. Z0.25 G01 Y3.5 Z0.25 G01 X4.875 Z0.25 G01 Y0.5 Z0.25 G01 X4.75 Z0.25 G01 Y3.5 Z0.25 G01 X4.625 Z0.25 G01 Y0.5 Z0.25 G01 X4.5 Z0.25 G01 Y3.5 Z0.25 G01 X4.375 Z0.25 G01 Y0.5 Z0.25 G01 X4.25 Z0.25 G01 Y3.5 Z0.25 G01 X4.125 Z0.25 G01 Y0.5 Z0.25 G01 X4. Z0.25 G01 Y3.5 Z0.25 G01 X3.875 Z0.25 G01 Y0.5 Z0.25 G01 X3.75 Z0.25 G01 Y1.2221 Z0.25 G02 X3.625 Y1.1362 I3.5525 J1.3755 G01 Y0.5 Z0.25 G01 X3.5 Z0.25 G01 Y1.131 Z0.25 G02 X3.4257 Y1.1601 I3.5525 J1.3755 G01 X3.375 Y1.1899 Z0.25 G01 Y0.5 Z0.25 G01 X3.25 Z0.25 G01 Y1.2635 Z0.25 G01 X3.125 Y1.3372 Z0.25 G01 Y0.5 Z0.25 G01 X3. Z0.25 G01 Y1.3221 Z0.25 G01 X2.875 Y1.2116 Z0.25 G01 Y0.5 Z0.25 G01 X2.75 Z0.25 G01 Y1.1012 Z0.25 G02 X2.625 Y1.0472 I2.592 J1.295 G01 Y0.5 Z0.25 G01 X2.5 Z0.25 G01 Y1.0626 Z0.25 G02 X2.375 Y1.1709 I2.592 J1.295 G01 Y0.5 Z0.25 G01 X2.25 Z0.25 G01 Y1.8552 Z0.25 G02 X2.25 Y2.248 I2.4047 J2.0516 G01 Y3.5 Z0.25 G01 X2.125 Z0.25 G01 Y0.5 Z0.25 G01 X2. Z0.25 G01 Y3.5 Z0.25 G01 X1.875 Z0.25 G01 Y0.5 Z0.25 G01 X1.75 Z0.25 G01 Y3.5 Z0.25 G01 X1.625 Z0.25 G01 Y0.5 Z0.25 G01 X1.5 Z0.25 G01 Y3.5 Z0.25 G01 X1.375 Z0.25 G01 Y0.5 Z0.25 G01 X1.25 Z0.25 G01 Y3.5 Z0.25 G01 X1.125 Z0.25 G01 Y0.5 Z0.25 G01 X1. Z0.25 G01 Y3.5 Z0.25 G01 X0.875 Z0.25 G01 Y0.5 Z0.25 G01 X0.75 Z0.25 G01 Y3.5 Z0.25 G01 X0.625 Z0.25 G01 Y0.5 Z0.25 G02 X0.5001 Y0.6199 I0.625 J0.625 G01 Y3.3801 Z0.25 G02 X0.625 Y3.5 I0.625 J3.375 G01 X3.75 Z0.25 G01 Y2.3424 Z0.25 G03 X3.625 Y2.4091 I3.5746 J2.1643 G01 Y3.5 Z0.25 G01 X3.5 Z0.25 G01 Y2.4082 Z0.25 G01 X3.3811 Y2.3968 Z0.25 G01 X3.375 Y2.4107 Z0.25 G01 Y3.5 Z0.25 G01 X3.25 Z0.25 G01 Y2.6982 Z0.25 G01 X3.2323 Y2.739 Z0.25 G03 X3.125 Y2.8575 I3.003 J2.6393 G01 Y3.5 Z0.25 G01 X3. Z0.25 G01 Y2.8893 Z0.25 G03 X2.875 Y2.854 I3.003 J2.6393 G01 Y3.5 Z0.25 G01 X2.75 Z0.25 G01 Y2.6668 Z0.25 G01 X2.6458 Y2.326 Z0.25 G01 X2.625 Y2.324 Z0.25 G01 Y3.5 Z0.25 G01 X2.5 Z0.25 G01 Y2.312 Z0.25 G01 X2.3807 Y2.3005 Z0.25 G03 X2.375 Y2.2999 I2.4047 J2.0516 G01 Y3.5 Z0.25 G01 Y2.2999 Z0.25 G02 X2.3807 Y2.3005 I2.4047 J2.0516 G01 X2.6458 Y2.326 Z0.25 G01 X2.7639 Y2.7124 Z0.25 G02 X3.2323 Y2.739 I3.003 J2.6393 G01 X3.3811 Y2.3968 Z0.25 G01 X3.5506 Y2.4131 Z0.25 G02 X3.7402 Y1.977 I3.5746 J2.1643 G01 X3.6127 Y1.8642 Z0.25 G01 X3.75 Y1.5483 Z0.25 G01 Y1.9862 Z0.25 G02 X3.7402 Y1.977 I3.5746 J2.1643 G01 X3.625 Y1.8751 Z0.25 G01 Y1.8358 Z0.25 G01 X3.7818 Y1.4751 Z0.25 G02 X3.4257 Y1.1601 I3.5525 J1.3755 G01 X3.0601 Y1.3754 Z0.25 G01 X2.7577 Y1.1078 Z0.25 G02 X2.353 Y1.3681 I2.592 J1.295 G01 X2.375 Y1.4402 Z0.25 G01 Y1.7789 Z0.25 G00 Z-0.1 M22 G00 X3.0601 Y1.3754 M12 G01 Z0 F0.5 G01 Z0.25 G01 X2.7577 Y1.1078 Z0.25 F1. G02 X2.353 Y1.3681 I2.592 J1.295 G01 X2.4628 Y1.7272 Z0.25 G01 X2.2778 Y1.8362 Z0.25 G02 X2.3807 Y2.3005 I2.4047 J2.0516 G01 X2.6458 Y2.326 Z0.25 G01 X2.7639 Y2.7124 Z0.25 G02 X3.2323 Y2.739 I3.003 J2.6393 G01 X3.3811 Y2.3968 Z0.25 G01 X3.5506 Y2.4131 Z0.25 G02 X3.7402 Y1.977 I3.5746 J2.1643 G01 X3.6127 Y1.8642 Z0.25 G01 X3.7818 Y1.4751 Z0.25 G02 X3.4257 Y1.1601 I3.5525 J1.3755 G01 X3.0601 Y1.3754 Z0.25 G00 Z-0.1 M22 G00 X0.625 Y0.5 M12 G01 Z0 F0.5 G01 Z0.25 G01 X5.375 Z0.25 F1. G03 X5.5 Y0.625 I5.375 J0.625 G01 Y3.375 Z0.25 G03 X5.375 Y3.5 I5.375 J3.375 G01 X0.625 Z0.25 G03 X0.5 Y3.375 I0.625 J3.375 G01 Y0.625 Z0.25 G03 X0.625 Y0.5 I0.625 J0.625 G00 Z-0.1 M22 G00 X0. Y0. M02
I have also attached the post I used to create the code. This post will work with V24 or V25
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
Neal
Nice, based on that document "//" will comment out the block.Code:M90 G98 P133 D1 G90 G70 G75 G97 S12000 G00 T1 // 1/4 FLAT ENDMILL - STANDARD G00 X5.5 Y0.625 M12 G00 Z-0.1 G01 Z0 F0.5 G01 Z0.25 G01 Y3.375 Z0.25 F1. G03 X5.375 Y3.5 I5.375 J3.375 G01 Y0.5 Z0.25 G01 X5.25 Z0.25 G01 Y3.5 Z0.25
Thanks for the quick reply : )
Al DePoalo
Al...
Your question caught my attention today as I just set up a multicam router with bobcad v28 and quickly discovered the multicam controller operates in ips, a question you asked about. multicam told me they don't have a way to change it to ipm, which is what bobcad uses.
And a call to bobcad tech support didn't help.
Did you come up with a way to translate so the post outputs the correct feeds?
Yes, old thread, sorry to dredge it up.
