Results 1 to 4 of 4
Thread: Mori Seiki SV 500 With FANUC controls
    Jan 2009
    Question Mori Seiki SV 500 With FANUC controls
    Hello,
    My company just purchased a used Mori Seiki machining center with a 2 pallet system. There appear top be three programs one of which is just a safe sub routine( redundant cycle cancel ect..).
    There are two other programs to run 20 pieces on each pallet.
    Can anyone tell me what these lines mean?
    G54 L20 P11 X___ Y___
    G54 L20 P12 X___ Y___
    G54 L20 P13 X___ Y___ ............
    and progresses up to P20.
    Can someone explain what the "L" word and "P" word do in the G54 work coordinate.
    bfedger
    Registered CNCRim's Avatar
    Feb 2006
    L is type of offset and P is the number of offset. Check your manual for more info.
    Feb 2009
    Some info he left out
    The SV50/500/503 pallet changer is a side mount, side by side. It seems to me there are sub programs from the factory to get A pallet/Bpallet and IF i remember correctly, they use those P commands for that.
    Jan 2009
    Thank You
    Thanks guys. I appeciate it. I will check out the manual if I can find them
    Thanks again
    Bfedger
  1. Mori Seiki SL-20 Fanuc 10T
    By premier_industr in forum Fanuc
    Last Post: 12-15-2009, 08:55 AM
  2. Need Help!- mori seiki SL-3A lathe w/fanuc 6
    By enrique flores in forum Mori Seiki lathes
    Last Post: 07-16-2009, 05:24 PM
  3. Connecting Mori Seiki Controls to a Network
    By gm3211 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 10-23-2008, 06:04 PM
  4. G & M codes for Mori Seiki SL-3 w/ fanuc 5T
    By jolulank in forum Mori Seiki lathes
    Last Post: 08-17-2008, 05:16 AM
  5. Mori-seiki/ Fanuc 11T Turning
    By B_Bueno in forum G-Code Programing
    Last Post: 11-10-2006, 10:33 PM
