Soft keys? under the screen? or the whole panel not working? Any alarms? Is the edit key switch turned to lock ?
Take apart the ATC plungers before you run it and clean/lube them. It will throw tools if you don't.
Hello
I have a mori m300a with a 10m control machine has been sitting for over a year with no power have it fired up on a phase converter but have no soft keys. I believe all parameters are gone,where do I get started to bring this machine back to life? I have a backup of all parameters .
Soft keys under the display and the nc/pc key does nothing ,key is not in the lock mode have tried it both ways , reset and # pad seam to work.
Ok did what everyone sugests when I hit 6 input it gives me a screen that comes up (F10m9b 1044) below that is (L1111 EMUL) FFC5FA FFC5B0 FFC5F0 ,If I reset it takes me back to the IPL PAGE ,still have no soft keys or nc/pc keys to be able to get to paramiter page to install them what I am I missing?
You can not just enter parameter mode if you have the IPL page up. You must first enter all the option paramters in hex format, then you can load the rest.
To enter in option parameters
1) Power up machine with "-" minus and "." decimal point depressed
2) Key "99" and "Input"
3) Key in "3" or whatever # axes in parameter 9000 @ "AXIS" prompt
4) Step through options by number and key new Hexidecimal codes and "input"
option 1=9100, option 2=9101 ect. Just push input if no change is required
5) If "clear files" appears, hit "Y" - will erase programs etc.
6) When 1st menu appears, key "6" and "enter"
-Then enter in your PMC parameters timers,counters,keeprelays. These will have to be entered manually.
-Enter in your communication parameters (manually). Now you can reload all of your parameters via RS232.
Stevo
