Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Mori help please
    Mar 2011
    Mori help please
    I have installed a 1999 mori sv4. It powers up homes, spindle runs. All the axis
    move ok. It will not change tools or pallets. Any thoughts of what might be the
    cause.
    Feb 2009
    Sv40?
    Custom-operator panel-aux function lock
    Make sure it's off.
    Mar 2011
    It is off. Any other suggestion. The machine was moved from Chicago to Lufkin Texas.
    Worked in Warehouse but does not now. Carousel will not move tool changer does not work
    and pallet changer does not work.
    Feb 2009
    Go to custom, atc manual, and let me know what is highlighted.
    Is the atc home position led lit up on the panel?
    And what happens if you call a tool in mdi
    Pallet change, make sure your incoming phase is correct and the hydraulic pump spins the right direction. Easy way to tell is to fire the coolant pump and watch direction. If backwards Change incoming lines. Also, does the machine go to pallet change position when you call the apc macro?
    is the apc led lit up on the panel?
    Mar 2011
    Custom atc panel
    pot up
    Arm home position
    Tool clamp
    ATC home is lit
    MDI Pallet change. Cycle light comes on and just sites there
    Rotation is correct
    Does not do anything in pallet macro
    I can do MDI G91 G30 P3 X0 Y0 and it moves to change pallets
    Will not move in custom menu
    Feb 2009
    Ok, what I'm about to tell you, please be careful with. Command an m31 then try a tool change. Pallet won't change if you didn't hit the set up complete button, however m31 will bypass all interlocks.
    Turn off and back on to re set the m31. M31 will still not bypass any doors, but it will ignore pretty much everything else.
    Mar 2011
    Did not work.
    The manual tool clamp-unclamp buttons do not work.
    The table will not unclamp.
    Is there anything that ties these two functions together
    Feb 2009
    Just the door lock switch as far as i can remember.
    Mar 2011
    The door for the pallet is open. I have tried to close it but no luck.
    It is like the air solenoid switch is not getting a signal.
    Mar 2011
    Got the tool changer working. The pod has not going all the way up.
    Now it all works good.
    Feb 2009
    Thats good, but on one of your last posts, you had an ATC home position lamp on, and pot up highlighted. Did something change?
    Mar 2011
    Not that I know of. I opened the door and the manual clamp and unclamp worked.
    I went to custom and did a pod up and heard it move. Then it started working.
    Now I am working on pallet changer
  • Page 1 of 2 12 LastLast
    1. Mori and DMG
      By underthetire in forum Mori Seiki Mills
      Last Post: 02-05-2012, 04:29 PM
    2. Okuma-Mori or Mori Dura
      By KKM in forum Okuma
      Last Post: 11-08-2010, 06:43 PM
    3. Mori MV 35
      By SteveY in forum Mori Seiki Mills
      Last Post: 10-29-2010, 04:26 PM
    4. Mori NL
      By positiverake in forum Mori Seiki lathes
      Last Post: 12-16-2009, 11:04 AM
