Results 1 to 5 of 5
Thread: Mori MVJR MX2 Controller
    Jun 2011
    Exclamation Mori MVJR MX2 Controller
    Okay guys, working on the junior today just got it up and running again after years of sitting. In manual mode I activated the M06 function for tool change. It grabbed the pot and brought it down andthat is it. I cant get it to place into spindle or anything, How do I get it to place the pot back into the tool changer?
    This activated the ATC cycle start function.
    Any help would be greatly apreciated.
    Thanks, Logan
    May 2007
    If you don't have the manuals, you can download them from the yaskawa web site.
    The procedure is explained in the manuals.
    You need to have the spindle at least 300mm -Y from the machine origin before doing M06
    Feb 2009
    First, Yaskawa can't help, its a builder side problem. Second, Y axis has nothing to do with the ATC sequence. I have the procedure for re-setting the arm, unfortunately not the pot up/down. Mori should be able to Email you the procedure. It is pretty straight forward, just release the interlock (m31 i believe) then fire the pot up Mcode.
    May 2007
    I have the printed manual out in the shop that explains the proceedure, I'll bring it to work, scan it and post it tonight.
    May 2007
    Attached find the instructions for returning the automatic tool changer to working order for an MVJR
    Attached Thumbnails Attached Thumbnails Mori MVJR MX2 Controller-mori_atc.pdf
    1. Mori MVJR with MX2 control trouble
      By schmidtmotorwor in forum Mori Seiki Mills
      Last Post: 01-03-2012, 06:06 PM
    2. mvjr tool release issue
      By andyhol in forum Mori Seiki Mills
      Last Post: 01-13-2011, 05:37 PM
    3. mvjr tool changer adjustment
      Last Post: 01-13-2011, 05:23 PM
    4. mori tv300 msc802m controller
      By Gedley in forum Mori Seiki Mills
      Last Post: 07-15-2008, 08:27 AM
    5. Replies: 0
      Last Post: 02-03-2006, 06:58 AM
