Results 1 to 4 of 4
Thread: PROGRAM PROTECT
    Oct 2009
    CANADA
    PROGRAM PROTECT
    HI EVERYBODY,
    WE GOT A MORI SEIKI LATHE NL 2500
    WITH MSX-850 CONTROLER
    I WANT TO KNOW IF IT'S POSSIBLE TO LOCK A PROGRAM
    TO MAKE IT IMPOSSIBLE TO MODIFY BY THE OPERATOR
    THANK!
    Aug 2008
    Not that I know of.
    Easiest thing to do is leave the Panel Edit key in the "On" position then remove the key. You cannot edit program without the Panel Edit key in the Edit position.
    Jul 2007
    There are two ways to lock out a program on this control besides the edit lock key that will lock out all programs.
    If you go to the Process parameters there is a parameter called Ebit Lock B. Once on this will lock any programs between 8000 - 9999. If you want to go deeper you can turn on edlk c in the Base Parameters which will lock out programs 9000 - 9999. Mori may have this parameter already turned on but I can't remember if they turn it on or not.
    Oct 2007
    united states
    Yes, they come with that parameter already turned on, the 8000 and 9000 programs are protected to start with
  1. Need Help!- Password Protect Programs
    By Kurt Tedford in forum Fanuc
    Last Post: 05-20-2009, 07:05 PM
  2. diodes to protect drives?
    By m8kingit in forum General Electronics Discussion
    Last Post: 03-09-2009, 08:58 PM
  3. FANUC 15T Write Protect
    By bmlw in forum Fanuc
    Last Post: 10-11-2008, 03:47 PM
  4. Replies: 11
    Last Post: 04-14-2008, 12:31 PM
  5. Protect your G54...G59
    By jorgehrr in forum Fanuc
    Last Post: 09-30-2007, 08:11 PM
