I am having trouble moving the base of the tail stock in my mori seiki sl-65 with an msc-516 control. I can get the quill to move in and out, but i can't get the main base to move at all. any advice or insight would be greatly appreciated.
Is it a manual base, the kind that has 2 bolts on the side of it and an engagement block? Or is it a fully programable base that moves with the shot pin on the turret cross slide?
If it is a manual base, the 2 bolts have to be fully loose to get the engagement block to rotate up into the turret cross slide. There is a cam inside the base that will not allow the engagement block to rotate if the bolts are not fully loose.
A programmable tailstock can be retaught by using Tailstock Joint Mode on the option panels.
thanks for your quick response. the machine has the fully programmable base, but when we line the shot pin up with the tailstock, Tailstock Joint Mode will not engage. Is there something i am supposed to do to get it to engage?
Line up the shot pin and press both the Joint Mode and Unclamp push buttons at same time. Hold for 5 sec. then release. Shot pin shoul come out and reteach position of tailstock.
