Results 1 to 2 of 2
Thread: CL2000 drill cycle
    Jan 2009
    u.s.a
    CL2000 drill cycle
    Is there any body out there that would know the drill cycle for the cl2000 turning center fanuc code,,,I think that is g80,,,but not for sure ,,and if possible give me an program line example,,,I think it should look something like this,,,,G80 K... D.... not sure about the rest,,,appreciate any help thats out there thx eric,,
    May 2007
    G80 cancels G80 series calls. Lathes we have that use a G80 series code use them for live tooling only. Looking at a Fanuc manual, I would say that the code you are looking for is G83. Format is:
    G83 X(U)_ C(H)_ Z(W)_ R_ P_ F_ K_ M_
    where K is the number of repeats if need and M code is for C-axis clamp when needed.
    G74 is usually the standard Fanuc drill cycle. A 2-block call is
    G74R_
    G74X(U)_ Z(W)_ P_ R_ F_
    Format for a single block call is
    G74Z(W)_ K_ F_
    The distance the tool retracts is set by a parameter.
    Do you have Macro B? Is so you can write your own drill cycle. I have posted the Hardinge canned cycle several times for Fanuc contols. It is simple to use and very effective. You could search for it if you'd like to see it, or I can repost it for you. (Or PM you)
  1. C Axis Drill Cycle
    By gtrrpa in forum Parametric Programing
    Last Post: 06-15-2008, 03:12 PM
  2. Newbie- Drill cycle for FANUC
    By slowhandd in forum Commercial CNC Wood Routers
    Last Post: 02-25-2008, 11:02 PM
  3. canned drill cycle
    By nitrosnfr in forum General Metalwork Discussion
    Last Post: 05-24-2006, 11:50 AM
  4. error in drill cycle
    By TPPJR in forum OneCNC
    Last Post: 01-28-2006, 01:21 PM
  5. G83 peck Drill cycle
    By Vaughan in forum G-Code Programing
    Last Post: 03-19-2004, 12:11 PM
