Results 1 to 4 of 4
Thread: Mori SL-25 Programming
    Feb 2012
    united states
    I am having troubles running this g71 code any help would be appreciated. It comes up with an alarm saying faults in finish shape 0466. This is a yasnac controll. Thanks
    N10(PROFILE TOOL)
    G50S1500
    G0T1010M8
    G96S500M3
    G0G42X1.400Z.1
    /G71P100Q101U.02W.002S200D500F.004R1
    N100G0X.825
    G01Z.02F.0015
    G03X.984Z-.2R.4125F.004
    G03X.825Z-.4R.4125F.004
    G01X1.225Z-2.02F.004
    G03X1.00Z-2.420R.550F.004
    G01X1.125F.004
    Z-3.1
    N101G0G40X1.4Z.1
    X5.Z10.
    T1000
    M1
    G70P100Q101
    G1Z.02X.825
    T1000
    M1
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    The program works fine. see pic below.
    You have not activated Type II G71 cycle.
    Try adding a Z value on the first move line after the G71 line (i.e N100 G0 X.825 Z0.1)
    You may get another error about 'not monotonous' tool movement.
    That means you don't have Type II roughing cycles option.
    In that case program the part using G71 without any undercuts then go back and rough the undercuts with long hand code then take your finish pass not using the G70 (i.e. just copy/paste the entire finish profile below the roughing cuts)
    Or with the added Z value on N100 line you may be lucky having G71 Type II and it will just work.....
    Attached Thumbnails Attached Thumbnails Mori SL-25 Programming-untitled-1.jpg
    Mar 2012
    try this
    N10(PROFILE TOOL)
    G50S1500
    G0T1010M8
    G96S500M3
    G0GX1.400Z.1
    G71U.05(DEPTH OF CUT)
    G71P100Q101U.02W.002F.01
    N100G0X.825
    G01G42Z.02F.0015
    G01X1.125F.004 ( DON'T NEED TO KEEP ADDING FEED RATES UNLESS YOU NEED TO CHANGE IT)
    Z-3.1
    X1.4
    N101G40
    GOX5.Z10.
    Aug 2011
    Fordaville
    Moving the G42 won't make any difference. The first line after G71 (N100) MUST contain a Z value or W0 in order to active type II roughing cycles.
    Also its an older Yasnac control so it requires the older G71 format where all the info is on one line. The 2-line cycle format did not exist until Fanuc series-16 was released in early 90's.
  1. MORI JR
    By CNC2NUT in forum Mori Seiki Mills
    Last Post: 09-26-2011, 08:13 PM
  2. Used Mori
    By RSLaser in forum Mori Seiki lathes
    Last Post: 08-23-2011, 01:18 PM
  3. Mori AL-22S
    By emexcee380 in forum Mori Seiki lathes
    Last Post: 05-18-2011, 10:26 AM
  4. Okuma-Mori or Mori Dura
    By KKM in forum Okuma
    Last Post: 11-08-2010, 06:43 PM
  5. Mori MV 35
    By SteveY in forum Mori Seiki Mills
    Last Post: 10-21-2010, 01:25 PM
