| Mori Mills Discuss Mori Mills here. |
| On my Duravertical, G332 sets the cutting mode. R1. (speed priority) - R4. (better accuracy) For example: G332 R1. (SET CUTTING MODE) G05.1Q1 (ACTIVATE AICC) I had Mori tune the settings for R1. to get the fastest and smoothest motion while roughing at high feed rates. I usually use R2. for finishing. Surprised at how fast and smooth the machine is with AICC. It's only a 0iMC after all. |
| So you use them together? This is a little confusing to me as it was explained to me that all I would need to use is the G332 and that it "replaces" the G05.1Q1. I am trying to create a post and am trying to get the correct information before getting too far. Thanks for the reply! |
| Yes, they are used together. Once the cutting mode is set you don't have to write it in unless you want to change it again. So, if for example you wanted to use R3. on all tools, just write in in for the first then you only need G05.1 for the rest. From memory the default is R3. if you don't set a cutting mode yourself. Have you got manuals for the machine? it should all be there. Still doesn't make much sense initially though...... For my post, I have it writing in G332 R3. every time. I just manually change it to suit roughing or finishing. I guess I could have the post automatically write in the appropriate setting...... |
| I dont have the manuals yet, and in fact I do not even have the machine yet. I am trying to prepare for it. I have been talking to the applications guy and he gave me a post for the machine but it is mucked up. It doesnt post B axis rotations and it is set up to post for HPCC rather than AICC. We purchased the machine with level 2 AICC (hope that I am not lying here) so the codes that he is telling me will work with our machine I dont think are correct. I emailed him today and he is still telling me that I use G332 R1-4 in conjunction with G5 P1000, which if I am not mistaken, is HPCC. I think that one of us are confused. I better make that both of us. I have managed to create a post that outputs the high speed machining code but i need confirmation. After what you have said here, the G332 is not used until the High speed machining code is fired? is that correct? Thanks! You are definitely helping. |
| Well firstly, remember my machine has the 0i control, so it may be different. I did purchase the AICC option though, but it would be more basic than what is available for the NH. The manual says that G332 is used to set the cutting mode when using "AI look ahead/AI contour control" So the answer to your question is Yes, G332 is only used once hsm is fired. Other ways to set the cutting mode are the "cutting mode selection" screen or setting the cutting mode with a MAPPS parameter. To me, it seems best to always use G332 so you can change the cutting mode to suit the operation you are doing. That works well for me, and the difference is definately noticeable. My machine doesn't use the G5 P1000, etc. Not sure if that is for HPCC or AI nano or what. Here's some pics. One showing some code where I have used AICC, and the other showing the "status" notice the "R3." The blank box flashes "AICC" when activated. |
| Ok, a couple of things, First, here is what our applications guy sent me today. It cleared some things up.
Next, Ive been reading about having to use this G49 cancel tool offset prior to recalling the high speed function. Ive also read that you cannot change the G332 R value until the High speed function has been canceled. I was curious about a scenario. If you are machining aluminum at very high speeds, and roughing and finishing with the same tool, you could not very well cancel the high speed function and add a g49 in the middle of a single tool cycle without a crash could you? The reason that I wondered about this, was if you wanted to use a G332 R1. for the roughing, and then to run a finish contour, change to a G332 R3. I assume that this scenario is not possible? |
| I always finish with a different tool, so have never tried to change the G332 on the fly. I could write it into a program to see what happens..... I guess the safest way to change the R value would be to return to Z0 as if you were doing an M6. Cancel and recall AICC with the new R value, along with cancelling and recalling your tool offset as well of course. With the NH it would probably take less than 2 seconds |
#10
I am curious to know if your control runs windows in the background or not. We have an NH-4000 (2005) MSX 501 and it runs Windows. Kel1 |
| Mori-Seiki , Fanuc 6M diagnostic question | MITYDR | Fanuc | 10 | 07-07-2011 09:02 PM |
| Mori Seiki SL-20 Fanuc 10T | premier_industr | Fanuc | 7 | 12-15-2009 08:55 AM |
| Mori Seiki sl1 threading question | panaceabea | General Metal Working Machines | 3 | 10-08-2007 11:58 PM |
| Mori Seiki interface on Fanuc 18i HELP | gup | Fanuc | 6 | 03-20-2007 10:54 AM |
| Mori Seiki NH4000 T com | pieface | General CNC (Mill and Lathe) Control Software (NC) | 9 | 12-31-2005 05:41 PM |
