Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori Mills
Mori Mills Discuss Mori Mills here.
Old 08-09-2009, 10:11 AM
CNCgal is on a distinguished road
Exclamation NH5000 beta servo parmeters
Just installed a beta drive for the tool length detection. This machine had one prior and when it went down for a broken drawbar the beta drive was stolen for another NH5000. I have the original parameters in the book from Mori, however, I'm not sure which ones are for the tool length which is unit 7 on the machine.
The machine also lost zero position because the drive was out of the machine and thus didn't have a complete circuit for the batteries. I was going to put everything on the marks in the machine, however, the only marker that is still in the machine is for Z-axis. Nothing for X, Y, or B. I figure the next best thing it to put a machined part in the machine and use that as a known point and go backwards with the positions in the program and tool offsets then reset 1815.4. Are there any suggestions to be more accurate so we don't speed a week dialing in the machine?
Any help is appreciated, thanks in advance.
Old 08-31-2009, 02:22 PM
nakatome is on a distinguished road
hi just worked on an NH4000 replace x axis servo amp had to set up ref zero with arrows ,but in the manual it showed under sheet metal location for 10mm pin to be incerted for atc xy zero position be sure to remove pin before moving axis
nakatome
Tags
beta drive parameters, nh5000, zero position
TurboCNC v5 beta samco TurboCNC 9 09-15-2009 08:50 PM
V12 in Beta Test Now tobyaxis Alibre Design 0 07-19-2009 02:30 AM
NCPlot v2.05 beta 2 now available MetLHead NCPlot G-Code editor / backplotter 0 05-16-2008 11:00 PM
Mori Seiki SL15 dump parmeters & were not backup john neathery Machine Problems, Solutions , Wireless DNC, serial port 2 08-08-2007 08:47 AM
Beta 7 Available robgrz Product Announcements & Manufacturer News 2 09-28-2003 08:13 AM
