| Mori Mills Discuss Mori Mills here. |
| help me mr. wizard Hi all. I've been given a "problem" to figure out by my supervisor. I am running a Mori-Seiki SV-50, control FS-15M. There is a light on the top of the machine which shows green while the machine is in cycle. My manager noticed that the green light is sometimes on at other times. I experimented with it and found that using MDI mode would cause the green light to come on, and that it would stay on till given an M30, either from a program cycled or in MDI. He is adamant that this is a problem which needs to be fixed and I would like to satisfy him. Can anyone help me? |
| Cycle Start Hello, It appears as though the Pat light (Signal Tower) is tied into the Cycle Start of the CNC. That way, when Cycle start has been activated, the green light is on. Unfortunately, any cycle start will activate the green light, whether in Auto mode or MDI mode. You can try tying in the green light of the signal tower to the Spindle On signal, that way the light will be on only during spindle operation. Or the other option, which may be quite expensive, is to get some type of monitoring software, like Predator, or something. |
| thanks Thanks for your answer. Anyone else have any ideas which might work without reprogramming the ladder logic. Doesn't seem to be controlled by a parameter as I'd hoped. |
| I see you have a duplicate post happening here ![]() I took it to be a Fanuc 15 from your other post, but it looks like I may be mistaken.? Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Pat light SV50 would be a 16 or higher. I've NEVER seen a 15 on a SV. Only way to change the status of the light is to change the ladder, or wire the light to an external M code. |
| thanks You're right, it is an 18 control. I got in a hurry and just copied data from the CAP screen. I am an idiot. It was handy to be able to give my supervisor an answer in a timely fashion. Our maintenance man agrees with you. Thanks to all who answered me. |
| New Wizard | Shinosky | Mach Wizards, Macros, & Addons | 75 | 09-20-2010 12:31 AM |
| Help, Mr. Wizard !!! | emexcee380 | Mori Mills | 10 | 03-10-2009 07:31 PM |
| Need Wizard | mungaro | Mach Wizards, Macros, & Addons | 6 | 04-12-2008 05:59 PM |
| Nesting Wizard, Mach3 internal wizard. | thuffner3 | Mach Software (ArtSoft software) | 1 | 03-04-2007 09:38 PM |
| Shapes Wizard | rweatherly | Mach Wizards, Macros, & Addons | 0 | 05-23-2006 09:24 AM |
