Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori Mills
Mori Mills Discuss Mori Mills here.
Old 06-14-2009, 05:31 PM
Scottyb is on a distinguished road
Question Help NH4000 HORIZONTAL PALLET CHANGE
I have entered the work number for the pallets A and B, but it does not seem to load and run the proper program.
I end the program with,
M60;
M30;
Percent sign
The M60 calls a subroutine 900?
I haven't found anything in the manuals.
It also errors with "Program number not found".
New at this machine, first part program with 2 pallets.
Scott Bridges
Old 06-14-2009, 07:26 PM
rlabonte18 is on a distinguished road
I am a repairman and don't know a whole lot of programming but I think you need to input the program number as the work number. I am not at the machine now but I think it is somewhere if you press the setting button and there should be a work soft key that comes up on the bottom of the screen. These are the program numbers for pallet a+b which I think changes during the m60 command.
Old 06-14-2009, 08:00 PM
avtechmachine is on a distinguished road
did you Zero return all 4 Axis and press the ready switch to "ON" position for pallet change?
Ahn Vuong
Old 06-15-2009, 03:24 PM
I checked our program today and this may make sense to you but before the M30 we have an N60 not a M60 which is my understanding calls up a O100 subprogram for the pallet change. Make any sense?
Old 06-15-2009, 08:39 PM
Thanks All
Yes I have entered the work number , the program number for the pallet A and pallet B.
The machine works ok I just have to be sure I have the right program for the right pallet.
Usually the N60 would be a line number or block number.
I found that variable #147 holds a #1 for pallet A in the work position , and #2 for pallet B.
I may have to write a macro program and sub call the right program.
Thanks again.
Scott Bridges
Old 06-15-2009, 09:40 PM
I have also found that M60 pallet load, and M61 pallet unload??
I tried M61 from MDI and it didn't do anything but freeze, hit reset to return.
Scott Bridges
Old 08-18-2009, 09:00 PM
I have found that you must :
g91g30z0.
g28b0.
the table must be clamped, then parameters set correct, a m02 or m30 will search for the program # for the correct pallet and the setup station ready button pressed, it will work.
My problem error 59 program # not found was the result of 8 digits in the work number setting, and all programs were ? 4 digits long.
Thanks to Tim .
Scottyb
Old 08-24-2009, 11:14 AM
underthetire is on a distinguished road
Pallet change
Look at the Mcode list in the back of the Ladder book. I think M60 is just change pallet, M61 is pallet A, M62 is pallet B
Old 08-27-2009, 09:26 PM
It is running fine now. Running programs on both pallets, you need to have the pallet set in the pallet change position at 0, and locked, only to us a mo2 or m30 and have the workstation ready button pressed, and it will index and run the program specified by the work number set.
Scottyb :]
Old 11-25-2009, 09:22 AM
the thrill is on a distinguished road
well, this is an old post and you fixed it but the problem you were having was you were using M60 to command your pallet changes. Mori horizontals using the work number screen automatically pallet change on M30 with the button pushed in. You had one too many commands and were confusing the machine
Pallet Change Speed 68 SS Fanuc 4 09-19-2008 10:36 AM
Need Help!- HAAS HS-1 Pallet Change problems cweiss Haas Mills 3 07-30-2008 05:42 AM
pallet change program, needed stew Fanuc 0 01-02-2008 02:45 PM
Pallet Change CNC Mendez G-Code Programing 6 07-25-2006 01:50 PM
