Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori Mills
Mori Mills Discuss Mori Mills here.
Old 06-03-2009, 10:03 AM
KJ45 is on a distinguished road
MV-40 Tool Changing Errors.
We have a Mori MV-40B with Fanuc MF-M4 controls.
we are experiencing two seperate problems.
(1) - When T1 is in the machine and we run a program that uses T1 we get an EX0202 SPINDLE TOOL COMMANDED error. We have been getting around this by having the machine pick up T2, then starting the programs.
(2) - We are only able to use T1, T2, and T4 - if we try to use any other Tool we get an EX0201 IMPROPER TOOL COMMAND error. We have not been able to figure this out.
I appreciate you taking the time to help in this matter.
Old 06-04-2009, 11:21 AM
dbstream is on a distinguished road
1) D548.6 change to '1'
2) Press Aux/Graph Function Key to enter "Menu".Push softkey for "Tool Number" to enter into Tool Selection Page. You need to assign T code to the appropriate pot and "write" to keep data.
Good Luck!
Old 06-09-2009, 01:11 PM
underthetire is on a distinguished road
MV40
The tool in spindle alarm is a keep relay. Don't know what one off hand but that is the normal factory alarm if the same tool is called up in the spindle. The keep relay's are in the back of the Ladder book.
Old 06-15-2009, 08:12 AM
Good Luck!
Thanks for your help DB
We were able to fix the tools (problem # 2) with your help.
I am not sure what you mean by D548.6 - I can't find this information anywhere.
Old 06-15-2009, 08:13 AM
Thanks for your help under.
I am not sure yet what this means, but I will look into this week.
Tags
cnc mill, error, mori seiki, problem, tool changer
Changing tool diameter in the tool offset screen Vern Smith Haas Mills 21 09-24-2008 10:54 AM
Mach 3 Z errors? Crashed my tool! Shamanjim Mach Software (ArtSoft software) 5 05-22-2008 11:55 AM
R8 tool changing balibalistic Benchtop Machines 12 02-27-2008 07:24 PM
Help:possible M/c tool errors bala_51083 General CNC (Mill and Lathe) Control Software (NC) 0 04-14-2007 04:38 PM
Tool changing G30.1 ben92 G-Code Programing 0 11-17-2005 02:57 AM
