Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori Mills
Mori Mills Discuss Mori Mills here.
Old 05-21-2009, 09:55 AM
Ecmdrw5 is on a distinguished road
Exclamation NH-4000 Tool Setter Problem
I just got a new NH-4000 and i'm have trouble getting the tool setter to work. I've pulled the G324 program from the older NH-4000 and when I hit the cycle start it comes up with Set.ErrorSP.Position Z. I tried to call mori twice now and it says all ports busy. Any ideas?
Old 06-15-2009, 10:08 PM
Scottyb is on a distinguished road
Here is the program in our machine that works well for us.
There are parameters to be set, Tool to be measured, and off sets for large tools.
Hope this helps.
Scott Bridges
O1234(TOOL LENGTH MEASURE)
(SET #500=TOOL TO BE MEASURED)
IF[#500EQ0]GOTO3000
GOTO500
N500
T#500
M6
M19
M00(SET VARIABLES BELOW)
(SET #501=X AXIS SHIFT)
(SET #502=Y AXIS SHIFT)
G324X#501Y#502H#148R3
#500=0
#501=0
#502=0
M30
N3000
#3000=1(TOOL NUMBER NOT SET)
tool setter problem jimsy Fanuc 5 03-26-2009 08:16 PM
Need Help!- Tool Setter Macro for M-V60C and Metrol Setter mitshack Mazak, Mitsubishi, Mazatrol 0 10-06-2008 09:39 AM
Need Help!- Tool setter macro for M-V60C and Metrol setter mitshack General CNC (Mill and Lathe) Control Software (NC) 0 10-06-2008 09:38 AM
TOOL SETTER WITH G50??? DublJ Fanuc 0 07-30-2008 08:28 AM
What will cause this tool setter problem? Hogger Daewoo/Doosan 3 01-03-2007 08:52 AM
