Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori Mills
Mori Mills Discuss Mori Mills here.
Old 03-09-2009, 03:36 PM
tech5028 is on a distinguished road
MV40 alarm 12
I have an MV40 with Fanuc controls that is has alarm 12 which has to do with cables,motor or amp short.I've checked the cables and motor with a megger with good readings.Sent in the amp for repair and Fanuc had to do "minor" repairs but tested ok---until I got it back in the machine.Any thoughts??
Old 04-16-2009, 02:15 PM
RRL RRL is offline
RRL is on a distinguished road
Does it have the alarm 12 at power up?
If so remove the output wires to the motor and power up again and see if the alarm is still there.
Another quick test would be to run the spindle as slow as you can and check to see if it is smooth or not.
It is still possible the drive could be defective.
RRL
Old 04-16-2009, 11:59 PM
WGoyer is on a distinguished road
Alarm 12 on a Fanuc AC spindle drive means that excess current flowed in the drive. If the board is good, there is most certainly a shorted power transistor module. Fanuc's spindle maintenance manual has a few pages on how to test the modules. Be careful when changing the modules - the wires aren't marked.
Warren
www.uptimecorp.com
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 06:20 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 09:27 PM
MV40 major probs BigLozzy Mori Mills 6 03-05-2009 04:20 PM
Problem- Alarm 350, not in my alarm list, any ideas? ralph@nes Mazak, Mitsubishi, Mazatrol 4 09-27-2008 02:14 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 10:03 AM
