Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori Mills
Mori Mills Discuss Mori Mills here.
  #37   Ban this user!
Old 11-19-2010, 06:53 PM
Custom Billet is on a distinguished road
Hey Chris,
OK, ignore the tape part. Just type in the program number you want to run and hit input. The program on the NC will pop up.
The tool numbers will stay that way until you clear them and input your own numbers. And remember, the decimal is moved over one position. 2.000" is actually 20.000. I still haven't figured out what they were thinking on that.
The register is for registering which tool uses which offset. You want those to be set to correspond with the tool number. The H is the offset number. So tool 1 should use offset 1 (H1), tool 2, offset 2(H2)...ect.
Basically it is so if you have 1 set of 10 tools, and a second set of 10 tools, you can load the one set for a job, and have tool 1 use offset 1. On the second set of 10 tools for a second job, you can use tool 1 and offset 11, tool 2 offset 12. That way, you can put the first set of tools back in, you just program offset 1 for tool 1 on tool set 1 and you don't have to re touch off the tools. Don't worry about the aux. You don't need it.
  #38   Ban this user!
Old 11-20-2010, 07:17 PM
chrisclub is on a distinguished road
Thanks Jim. I was able to load the NC programs and edit them fine using POS/SEARCH
About the Z adjust...
Should the chamfer on the top of the pull stud on the tool holder contact the chamfer on the bottom of the channel on the spindle by .05 to .10 as it rotates into place?
This makes the tool holder bobble a bit, but it still gets engaged fine with the spindle as it slams down.
  #39   Ban this user!
Old 11-20-2010, 07:29 PM
Hey Chris,
You are talking about when the tool changer spins, the pull studs are just tapping the side of the spindle? If so, no, the Z height should be set higher. I would pull the table off and re-set it. I know it is a pain, but if you do it that way, it will be correct every time.
  #40   Ban this user!
Old 11-23-2010, 07:15 PM
I have an EMG EMERGENCY PLC alarm
and a M01 operation error 0101 and the spindle wont go up or down.
Any idea on how to release these alarms?
the Y1C2 (1) (2) trick doesn't work...
Thanks,
  #41   Ban this user!
Old 11-23-2010, 07:41 PM
That is NON-OP mode. The E-stop is in, or the air pressure is low. One of my machines has the air pressure alarm and the other does not, or it was bypasses by the previous owner. Check those two things out and if you are still stuck, let me know.
Jim
  #42   Ban this user!
Old 11-23-2010, 07:48 PM
Doh!
E-STOP was in because I had pressed it. LOL
  #43   Ban this user!
Old 11-23-2010, 07:56 PM
HA HA, yeah, sometimes that happens!
  #44   Ban this user!
Old 11-23-2010, 07:57 PM
Making parts?
5T G02/03 Circular Interpolation problems Dragoon2 Fanuc 13 08-07-2007 06:58 AM
mori seiki sv-503 problems mr-seiki General Metal Working Machines 1 11-28-2006 09:46 AM
mori seiki (G83 problems) ajl6549 General Metal Working Machines 2 08-31-2006 11:52 AM
Mori Seiki SL-25 (G83 Problems) ajl6549 CNCzone Club House 0 06-05-2006 03:11 PM
