| Mori Mills Discuss Mori Mills here. |
#13
With a 6M control I believe you need to go to the parameter table. I think it is parameter 4000. The sequence will have pot # and tool # 4001 is pot 1 the value is the tool # associated to that pot. I think the spindle tool is 4000. 4001 pot 1 4002 pot 2.... not positive on the exact # may not be 4000 but pretty sure. also there may be more than one parameter page. IE PC parameter and machine parameter. try calling Fanuc 888-fanucus. good luck |
#14
| pattawit: As I understand the problem is that if you choose to take tool 5 the machine goes and takes the tool from pot 10 (as an example). This is due to the random tool selection of your machine, this means that in order to do the tool change faster, the machine will leave the tool in the spindle in the pot where the next tool is, so, if you have tool 5 in the spindel and want ot load tool 10 the machine will take tool 10 and leave tool 5 in the pot where tool 10 was; this is random. The machine will remember wher is tool 5, and every time you call tool 5 it will go to the por where that tool is. If you arrange all the numbers of the tools to have tool 1 in pot 1, tool 2 in pot 2, etc. evantually the machine will missarrange that due to the random system. I hope this helps. Greg. |
#16
| Tags |
| fanuc 6m, mori seiki, mv45 |
| Need Help!- Bridgeport 760\22 Heidenhain 370 "error 2 tool def" | JNFSWE | Bridgeport and Hardinge Mills | 9 | 08-26-2008 01:45 PM |
| G320 "common" or "+5vdc" why do they vary? | beezerlm | Gecko Drives | 3 | 01-12-2008 04:00 PM |
| "tool slot number too large" code | dave6 | Mach Mill | 1 | 10-10-2006 05:57 PM |
| Vertical system "jerks" and "bangs"?? | REVCAM_Bob | Servo Motors and Drives | 5 | 06-12-2006 09:09 AM |
| Tool height "touch off" tool unusable | DHK | DeskCNC Controller Board | 6 | 05-06-2006 12:54 PM |
