Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori Mills
Mori Mills Discuss Mori Mills here.
Old 08-18-2008, 06:18 PM
stovepipesteve is on a distinguished road
can i feed in 3 axis on a Mori fontier M1?
i try to spiral interpolate but get alarms.(invalid axis). I can program a haas and a cincinnati and it works fine,but not the mori. I cant program any kind of thread mill operation,if i ever wanted to.
ive been told it was an option not bought ,but it can be turned on if you can find the paramater.
any suggestions?
thanks in advance
Old 08-18-2008, 06:31 PM
Old 08-26-2008, 03:56 AM
G00 G00 is offline
G00 is on a distinguished road
Hi i have mori seiki MV80 with a fanuc 11m and I get the same message when I try to
helical interpolate.
but the old mitsui seiki HR5 with a 6m does it fine! go figure.
Old 08-26-2008, 07:15 PM
DennyAppsEng is on a distinguished road
Opps...
Are using the correct code?
Cylindrical Interpolation : G07.1
If you MDI G07.1 alone what does your control do/say?
Improper or Invalid G code means its not been purchased. Other errors usally mean it will work if programmed correctly.
Wrong answer, Ill try to find the right one.
My bad.
Last edited by DennyAppsEng; 08-26-2008 at 07:22 PM. Reason: was thinking of differnet interpolation
Old 09-19-2008, 05:35 AM
*Registered User*
phix is on a distinguished road
Helical is an option on most Mori verticals. Your only move here is to call Fanuc and order the option, which in most cases involves changing one parameter bit.
SO, unless you know someone with an option parameter list and the know-how to change it, you'll have to buy it.
What control do you have? 21m?
Old 09-19-2008, 06:55 AM
holbieone's Avatar
holbieone is on a distinguished road
program it point to point
Old 11-07-2008, 10:26 AM
the thrill is on a distinguished road
have you tried programming a standard G2 or G3 with I, J and Z - feed?
auto feed 4th axis? Teyber Benchtop Machines 25 06-30-2008 11:37 AM
NX5 Mori 2 axis lathe post murrietafx4 Post Processor Files 4 02-28-2008 01:51 PM
mori seiki fontier-LII fanuc MSC521 BKCOM Fanuc 1 08-23-2007 01:31 PM
Mori Seiki Z axis Thrust Bearing TWyatt9 General Metal Working Machines 0 08-15-2007 10:25 AM
looking for X3 X axis feed screw gumba Benchtop Machines 1 05-20-2007 07:01 PM
