Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori Mills
Mori Mills Discuss Mori Mills here.
Old 06-04-2008, 02:45 PM
Gedley is on a distinguished road
mori tv300 msc802m controller
I am trying to turn off or delete the tool life setup.The mill stops when the program get to T5, thenreports " improper T comand". Please help.
Old 07-14-2008, 05:23 PM
Harri J is on a distinguished road
Gedley, I don't think it's a tool life issue. I can look switching tool life off tomorrow in the manual (if it's of any help) but my guess is you have registered T5 incorrectly (not registered at all or registered in several tool pots) This is what "Improper T command" implies. If you are using tool length comp you must also have a tool length set in the offset/tool offset menu. Worth a check..
Harri
Old 07-15-2008, 08:02 AM
Thanks Harri J, I managed to find the problem at T5, I left the ( off the tool description.
It is a long program and was very easy to over look a little error like that. Thanks for your input.
Old 07-15-2008, 08:27 AM
Hi Gedley, you're welcome & glad you sorted it out. Nice machine, annoying control It's taken me the best part of two years to fight through mine. Just "love" those cryptic error messages and parameter naming & input, designed by a bunch of dimwits
Harri
mori zl-15 code ? travis1 Mori lathes 2 01-17-2008 07:18 PM
Mori w/10T grease Fanuc 2 10-26-2007 06:10 PM
DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller maycom DeskCNC Controller Board 1 06-02-2007 02:33 PM
mori with t6- b controller sample program needed anyfish Fanuc 0 02-03-2006 06:58 AM
mori dj stu Post Processor Files 3 03-17-2005 01:14 AM
