Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori Mills
Mori Mills Discuss Mori Mills here.
Old 06-04-2008, 10:32 AM
v.sundermoorthy is on a distinguished road
Mori seiki MV40E memory card problem
Hey anyone and everyone with the machine MV40E control is fanuc 21i-MA the machine works fine but when I use memory card in the front of the monitor and chose the card option by soft key immediately the machine will come out with alarm 7164 - SPN-1 spindle drive error-AL-64
Why?
Old 09-09-2008, 03:48 PM
NL2000 is on a distinguished road
First off, you didn't state if you are using a CF card. It must be a CF card. Then pop it in your pc and format the card using the FAT file system. DO NOT use the FAT32 system.
Lastly make sure your I/O channel is set to 4 before inserting the card. You can do this from the settings screen or with parameter 20.
Old 11-10-2008, 05:17 AM
miloth2001 is on a distinguished road
Unhappy The same memory card problem on lathe Mori seiki SL300B
Control is fanuc 18i-TA
7164 - SPN-1 spindle drive error-AL-64 (but on spindle drive display is alarm 24 - SERIAL TRANSFER ERROR)
and 754 - SPINDLE–1 ABNORMAL TORQUE ALM
and 750 - SPINDLE SERIAL LINK START FAULT.
Noise or HW defect?
Old 04-20-2009, 03:35 PM
SteveGrant is on a distinguished road
You have an older model vertical which requires an SRAM card. Nowadays they are a bit more expensive than a standard memory card. The size you'll be looking for (to be safe) is 4MB (that's right MB not GB). The cards will go up to 8MB, but your machine may not like it. The SRAM card has a battery in it that the machine receives a pulse from. That's why your getting the spurious serial spindle alarm (no battery in the card you're using).
Need Help!- memory card read problem with 0iMC jhartleyjr Fanuc 6 05-30-2008 12:00 AM
Threading problem on Mori seiki zl-15smc DryRun G-Code Programing 4 09-19-2007 12:57 PM
Memory Card Cnm 1b avaitsis Machine Problems, Solutions , Wireless DNC, serial port 0 07-27-2007 04:45 PM
Mori Seiki ZL-15 Startup problem??? =ego= General Electronics Discussion 11 06-26-2007 04:07 PM
mori seiki mill with a spindle problem imwllc General Metal Working Machines 3 06-26-2005 07:31 PM
