Results 1 to 3 of 3
Thread: Mori Seiki MV35/35 MX1
    May 2009
    We have a Mori Seiki MV35/35. yasnac mx1 control
    Here is the problem : It zeros out fine, jogs, manual is fine, no alarms.
    If you command it in either MDI or Auto mode as soon as cycle start is pressed it just shows alm flashing on the bottom of the crt. No alarms on either the message or alarm page.It is the same for any m,s,t, or g code, it is same result. Only thing obvious is the contactor for the servos power supply drops out and diagnostic 1218.0 is high ( alm). We have done a regeneration of the memory, no difference. Any suggestions would be appreciated greatly.
    Apr 2012
    Have you put your system switch back to #0 after the regeneration ?Have you tried a simple M03 or M04 in a line by itself without an axis move? I do know that Yasnac's were known to have issues when programming M,S, & T's in the same line of program. Made a habit not to do that. No alarms on screen, but do you have any alarms on the drive amplifiers or DCP unit or spindle drive?
    Feb 2012
    The edit key turned on while in Memory (Auto) mode will cause this to happen.Check the key position.
  1. Problem- Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori lathes
    Last Post: 05-04-2011, 11:12 PM
  2. Mori MV35 240V 3 Phase
    By SteveY in forum Mori Mills
    Last Post: 11-23-2010, 08:54 PM
  3. Mori MV35/Fanuc 6M
    Last Post: 07-01-2010, 06:34 PM
  4. spindle belts for mori seiki mv35/40
    By brandou10l in forum General Metal Working Machines
    Last Post: 01-06-2008, 06:59 AM
