Results 1 to 3 of 3
Thread: z-axis servo alarm
    Feb 2012
    us
    z-axis servo alarm
    Got a nv 5000 and sv-50 giving me a z-axis excess error alarm at the end of each cycle.
    go 91 g28 z0.0
    m30
    ALARM.....z-axis excess error
    However, If I turn the door interlock switch off (disable) on both machines, no alarm will be generated on either machine. I noticed that the z-axis will drop approx. .200" off machine home position at the end of each cycle. When alarm is reset and machine is restarted machines return to home position. Could it be that the z-axis brakes not working properly is what is causing this alarm to generate?
    Feb 2009
    So, you get an excess error at end of cycle when the door unlocks?
    Yes, Z axis brake is not working correctly. The servo shuts off when the door opens, normal. You can take the brake off (block the head) clean it and adjust the tension screw a slight amount. maybe 1/4 turn at a time until you see less than .030 drop. Too much and the brake will drag and overheat.
    Feb 2012
    us
    I believe you are in fact overthetire my friend........Thanks for the help
  1. Problem- (ALARM 414 SERVO ALARM) Y-AXIS DETECT ERROR?
    By PICMAN in forum Fanuc
    Last Post: 11-09-2012, 06:11 PM
  2. Replies: 6
    Last Post: 04-29-2011, 06:20 PM
  3. Alarm 409-servo alarm- z axis torque alm
    By jessebpm in forum Hyundai Kia machine
    Last Post: 06-14-2010, 08:45 PM
  4. Need Help!- for the servo alarm 400 x-axis
    By pelletong in forum Fanuc
    Last Post: 06-07-2008, 05:01 AM
  5. Y-axis servo alarm #329
    By MIYANO vs FANUC in forum Fanuc
    Last Post: 01-12-2008, 11:38 PM
