What did Mori tell you while you had them on the telephone concerning this type of problem? 877-275-6674
I have a fanuc 10m in a mori mill getting a (d) alarm on main PCB .Been told main board is bad cant find the exact board to replace it has a A16B-1010-0190/04B in it now , have access to a A16B-1010-0190/05B will it work ? Been told as long as the first 12 digits are the same it should but not sure what the last 3 stand for or is the 05B just a update and the boards are the same . Thanks any help will be apreciated
http://www.kirkcon.com/
Should work fine. Revision change.
Mori refered me to Fanuc and they dont have any information on a little (d) alarm but suspected a main pcb fault.
Fanuc said replace main PCB problem is cant find a A16B-1010-0190/04B Board can get access to a 05B guess going to try that.
