Results 1 to 5 of 5
Thread: Yasnac MX-2 EPROM images (will trade!)
    Jun 2011
    I am an EE looking for the EPROM image of prom #40
    (the lower one) on the CP-07 board of a MV Junior.
    I managed to wipe mine, before I realized that I
    did not have a good image of it. Bonehead move,
    I know....
    I had previously imaged all of the EPROMs in the whole
    machine, for a rainy day, and that day has come.
    Unfortunately, EPROM#40 is a 27c256, while all the
    rest of the EPROMs are 27128's -- When I previously
    imaged the EPROM#40, I only read out half of it! -
    I wish I had paid more attention.
    So, to make a long story short, I need an image
    of #40 on CP-07. This is called the "ladder software"
    EPROM, (it ruins the ladder logic CPU on the CP-07)
    I will trade / share all of the other roms that I imaged
    for this, and I am willing to help others repair/give advice
    on the MX-2 (I have spent a TON of time reverse engineering
    the dam thing thanks to Yaskawa's totally-closed mouth
    nature of tech support)
    Thanks,
    ---Lou
    May 2007
    I have an MX2 but don't know how to get the information you need, if you can tell me how to do it, I can try as i am having problems with my control and will be working on it.
    Jun 2011
    Thanks, but I got it. Turns out that the U-40 IC is
    SUPPOSED to be a 27-128 - I had replaced it earlier
    this year with a 27256, and coped the data over both
    half's of the prom. This is what happens when you work
    too much! You forget your own "tricks" - so, bottom
    line is that I have all of the data I need.
    I still have a failing CP-08 board, though.. It runs
    for a while, and then either stops responding to the
    lower half of the keypad, or it comes up with a
    "Keep Memory error" - I think the ladder-logic PLC
    part of the CP-07 is going bad.
    I checked the voltage on the S-ram that holds
    the PLC data, its 4.8 volts with the machine off,
    so the problem really must be a hardware issue.
    I am going to replace some of the chips on the
    board that I suspect are bad - but that's a risky
    thing because the idiots at Yaskawa soldered each
    chip directly to the board. Even with good equipment,
    replacing the chips is a risky deal.
    Wish me luck.
    PS: anyone have a spare CP-07 they want to sell?
    ---Lou
    May 2007
    "PS: anyone have a spare CP-07 they want to sell?"
    I might be converting my machine to EMC2 if I can get some clues about how to do it. In that case I will have an extra one. I also know a machine repair guy that sometimes has them, I'll ask.
    Jun 2011
    Thanks, as I need to get this machine up
    ASAP - and getting a new board is the 100%
    fastest way to do that.
    1. Build Thread- Fanuc Eprom
      By MysticMonkey in forum Fanuc
      Last Post: 11-24-2009, 04:26 AM
    2. Newbie- Help cross referencing Eprom chips
      By nlh in forum General Electronics Discussion
      Last Post: 06-11-2009, 12:34 PM
    3. Fanuc Eprom
      By gabedrummin in forum Fanuc
      Last Post: 06-06-2009, 05:26 AM
    4. Techno MAC100A Eprom
      By shenlung in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 06-27-2007, 01:40 PM
    5. EPROM (?) info
      By brgrii in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-05-2006, 04:34 PM
