Results 1 to 2 of 2
Thread: macros
    Jun 2008
    macros
    I posted earlier but my boss gave me hte wrrong model # of the control panel, it is a MSG 803 on a cl203 mori lathe I believe mori added a few things to it. We just got this lathe in with no Manual.I"m trying to load a macro but when I go to call it in my program it alarms out.thee is a program in the libraryfrom previous owner called OP91103 When I left on Friday i hit the soft ke labeled MACRos and notices there were macros numbered from 101 thru 115. Does thes mean I can only use these numbered macros ? and if so what do I have to do if anything to make them active ?
    Thanks In Advance
    Jan 2011
    I believe the MSG803 is a mitsubishi M64 type controller with mori MAPPS-1. You can get mitsu programming manuals from Mitsubishi Electric Automation Inc. - MEAU Home and follow the download link.
    What sort of error do you get?
    There will be an alarm type number (i.e. P01) and a code (I.e. P01 - 101 etc) There are severl possible reasons you'll see an alarm, it might be that
    your call was missing some arguments, or that the macro has a syntax problem etc..
  1. Need Help!- MACROS
    By gtrrpa in forum Mori lathes
    Last Post: 11-17-2011, 01:57 PM
  2. New to using Macros
    By 905xray in forum G-Code Programing
    Last Post: 12-08-2009, 02:35 PM
  3. Need Help!- X3 CNC macros
    By trainfred in forum Syil Products
    Last Post: 05-20-2008, 08:42 PM
  4. Need Help!- help with macros
    By gj83 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 04-11-2008, 09:42 PM
  5. Macros
    By cncfreak in forum General CAM Discussion
    Last Post: 05-06-2005, 06:04 PM
