Results 1 to 5 of 5
Thread: BTR and 3D toolpaths Feedrates.
    Aug 2009
    I have an MV35-40 with a fanuc 6m control. When I run 3D toolpaths the machine is bogged by the processor and cannot run at the programmed speed(no look ahead). My question is if I use a BTR with a drip feed will I be able to achieve any faster feedrates? It seems that I would then only be limited by the communication from a pc to my machine? Has anyone retrofitted this machine? How much did it cost?
    Feb 2009
    You should have RS232 on the machine. Thats going to be the fastest. Even though a BTR might handle 19200 buad, the old tape readers could not, so it will still bottleneck feeding in to the actual control. Your major downfall on that machine is the block to block speed on processing, no way around that that I know of. Although, if the machine still has bubble memory in it, I have found data transfer rates slightly faster with the new Sram board from fanuc. About a 1500.00 board.
    Feb 2009
    And your log in name sure sounds familiar, the name of your shop? I was the local service manger for years in the No Ca Mori distributor.
    Aug 2009
    Thanks for the answer
    I've been thinking about either a BTR or retrofitting the machine. I am a homebrewer hence the screename. It used to be my standard beer till I started making beer. I will look into the new memory because I do have bubble memory I believe. Thanks Again. Cheers!
    Aug 2008
    BTR vs internal memory
    I can't imagine that any drip feed system for a 6T would be much faster than the internal memory. The parallel tape reader port probably gobbles up data 300 characters per second (3000 Baud). Most BTR's are put on Fanuc 6 controls by people who need to feed in very large files.
    I can say with certainty that a full bubble is slower than an empty one. I used to watch one particular machine load an entire reel of paper tape into the bubble. It would start off fast and slow down as the bubble filled up.
    Sometimes you can free up some space on a bubble with the "Cancel Orgin" routine.(While in Edit mode, press Cancel, then Orgin) This throws away all of the old edits that clutter up the bubble.
    Warren
    Uptime Electronics, Inc.
    1. More Q's! Feedrates, etc
      By binfordw in forum Benchtop Machines
      Last Post: 03-28-2010, 08:21 PM
    2. Problem- plunge feedrates?
      By spock in forum BobCad-Cam
      Last Post: 07-29-2008, 02:52 PM
    3. G0's and Feedrates???
      By Moondog in forum Machines running Mach Software
      Last Post: 04-18-2007, 04:26 AM
    4. Anyone got any X1 recommended feedrates...
      By digits in forum Benchtop Machines
      Last Post: 10-03-2006, 06:54 PM
    5. X1 Feedrates etc...
      By itsme in forum Benchtop Machines
      Last Post: 08-19-2006, 08:37 PM
