Not sure what parmeter it will be on your control but there will be a parmeter called Z grid shift that you can use to change it be sure you right down the orignal down be for you start adjusting it an I think you can look at you machine number on the Z axis when it is at home make a small adjustment rehome Z and check it again,
LinkBack URL
About LinkBacks
