Originally Posted by
fiearlacha
underthetire : thank you for your quick reply.
the only confusion for me then, is these are only there when I am getting the 7147 spn1: pos-coder signal abnormal alarm. I watched during pallet changes, everything appears to be normal. we are running with fixtures bolted directly to the tombstones.
Would it be possible that the clamping is not right on the APC so under intermittent cutting it has moved? there are 8 tools in the program, and this is the only one causing us problems ATM.
