Is it a VMC.
Can you send the photograph of the bearing and cam and sizeof the bearing like OD and ID .
I think it should be neddle bearing.
Do you have the manual fo the machine.
Regards,
Shivek
Hi all,
I nee to buy a cam baering from the ATC of a MV-40M vert. mach. center, Mori won't sell it unless I register the machine with them, it takes a lot of time.
I there a supplier (other than Mori) that could sell this part??
Than you.
Greg.
Is it a VMC.
Regards,
Shivek
All world machine parts in Chicago. You will need the bearing part number. If you tell me witch cam bearing broke I might be able to help.
