Results 1 to 3 of 3
Thread: Help Mori MV 35, Fanuc 6M B
    Feb 2010
    Just sat up this machine. The rookies decided to play with it while I was gone.
    It looks like they manually ran it past the travel limit in the Y- direction, then proceeded to over travel in the Y+ direction.
    Alarm screen reads;
    220 - +Y OT
    221 - -Y OT
    The table and ram travel in X & Z fine. The table won't come out of the Y+ OT position. Tried to JOG with Y-, NOPE, reset does nothing, manual control wheel won't back off the table from the y+ position. Reset won't kill either alarm.
    Everything worked fine until I left the building.
    What am I overlooking?
    Registered dcoupar's Avatar
    Mar 2003
    There may be an overtravel release switch (or pushbutton) in the electrical cabinet. Be sure you handwheel off in the correct direction.
    If not, you may have to shut the machine off and turn the Y ballscrew by hand to move it off the switch.
    Feb 2009
    Oh boy, early MV35's don't have an overtravel release switch. They had a jumper wire with alligator clips in the rear cabinet you had to use to jump a terminal block. I don't think thats really the problem though. My guess is a missing 24vdc common that feeds both the switches. Blown fuse, broken wire, or a bad switch.
  1. Mori M300A Fanuc 10m
    By cncmori in forum Mori Mills
    Last Post: 12-28-2009, 11:19 AM
  2. Mori Seki - Fanuc 11T
    By brourke in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 07-25-2008, 09:42 AM
  3. mori-fanuc 6t question
    By KENNETH BROWN in forum Fanuc
    Last Post: 01-10-2008, 02:07 PM
  4. Replies: 3
    Last Post: 07-13-2007, 11:42 AM
  5. Sl-3h mori w/ Fanuc 11t [alarm]
    By B_Bueno in forum Fanuc
    Last Post: 06-24-2006, 05:34 PM
