Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 12-01-2009, 06:25 PM
toolwrite is on a distinguished road
SL-3 SHUT DOWN
SL-3 It shuts down and makes noise in the inverter box during decleration. adjusted rh2 with no help. Help
Old 12-01-2009, 10:08 PM
Waynno is on a distinguished road
Sometimes helps if you post year and control make to solve problems,
also if recent change in ownership and hook up in diffrent shop
http://nosala.com
The Mori Seiki Underground Message Board
Old 12-02-2009, 05:24 PM
underthetire is on a distinguished road
sl3
More details. Shut down how ? alarm, breaker tripping etc..
Old 12-03-2009, 04:25 PM
1985 sl-3
Getting a ov error (#4) on decleration , adjusted rh2 acording to flow chart.
It worked for a short time. now has no affect. it will run for a while (makes noises while speed changes - from inverter) and eventually shuts down.
Incoming power within specs and tightened all connections.Had drive belts changed as well. Could it be the thermo relay?
Old 12-03-2009, 05:48 PM
sl3
Thermal overload relay won't make noise. AC drive i would assume on that year machine. May have regen resistors for the drive, may be bad transistors in the drive. I've also seen machines with too small input lines cause this problem, and transformers also cause this. What drive unit do you have ?
Old 12-03-2009, 06:44 PM
reply sl-3 shut down
The machine maintains power when it shutdowns. can reset inverter button. It has a Yasnac lx-1 control and a 626 mt2 b series inverter
Will the G320/G340 shut down southernexplore Gecko Drives 0 07-08-2009 07:13 PM
Shut down Due to Setting #1 Zak@CWS Haas Mills 1 10-27-2008 10:48 AM
Bad Weather Shut Down johnd Mach Software (ArtSoft software) 2 06-05-2007 09:32 AM
Makino shut down steedspeed General CNC (Mill and Lathe) Control Software (NC) 0 11-23-2006 10:43 AM
