Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 09-29-2009, 06:45 PM
littlerob's Avatar
littlerob is on a distinguished road
MAPPS
How hard is it going to be for me to learn "MAPPS"?
I know G&M code.
I use MasterCam but the new job I am starting wants me to use MAPPS.
So I was just wondering how hard it is going to be to pick up?
Thanks, Robert
Old 09-29-2009, 08:50 PM
WOLOG's Avatar
WOLOG is on a distinguished road
Mapps is not hard. I find that in order for you to do a program correctly you must really pay attention to the reference positions and origins. Your tool library must be set up correctly for accurate simulations/programs. Other than that, it does have its limitations but the simulation runs off of the G code so if you make a change to the program the simulation will change also. Changing the tool numbers in the programs screws everything up in the sim! If you are good at MasterCam, then Mapps should not be a problem. If you need specific help let me know.
Old 09-29-2009, 08:52 PM
littlerob's Avatar
Thanks WOLOG if I need some help I'll let you know.
MAPPS CNC sjh Controller & Computer Solutions 0 04-20-2009 05:44 AM
MAPPS Parameters for a Mori Seiki NL tminnig Fanuc 4 09-30-2008 04:57 PM
Mastrecam 9 or X for MoriSeiki NL2000Y - MAPPS III control Her_cnc Post Processor Files 1 11-15-2007 03:18 PM
Load meter / MAPPS parameter Ugene96rs Machine Problems, Solutions , Wireless DNC, serial port 0 10-19-2007 09:09 AM
MAPPS question RobinHood General Metal Working Machines 2 06-08-2007 12:04 AM
