Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 07-08-2009, 01:56 PM
SmokinErb is on a distinguished road
zl 200 transfer
when transfering slug from h1 to h2 ,machine stops with no alarm right after the m11 code ,is there a way to bypass machine recognizin that collet is open on head 1
This site changed my life ----> www.alittlebiteasier.net
Old 07-08-2009, 05:01 PM
Jawbreaker38 is on a distinguished road
Are you running through a collet or a chuck? Maybe try re-clamping head 1. I take it you're not cutting off or bar feeding?
Old 07-09-2009, 05:18 AM
its in a collet
no bar stock, just slugs. I don't have a problem when i am using barstock
Old 07-09-2009, 04:30 PM
I should have thought of this before, because I've had the same problem. What I ended up doing was using a spring loaded collet stop, on the end of it I threaded a slug approximately the same diameter as the collet diameter. After pick up it would release the the spring tension and the slug would be sticking out of the collet about .100. Then simply re-clamp the collet. I'm sure there is a parameter code, I know you can go into the custom table and switch it so it won't alarm, but you'd have to switch it every time.
Need Help!- file transfer valleyron Mazak, Mitsubishi, Mazatrol 0 10-16-2008 04:29 PM
transfer of program Dar Bridgeport and Hardinge Mills 10 09-13-2007 09:43 PM
File Transfer roninB4 CNCzone Club House 3 08-27-2006 11:05 AM
how to transfer? hop General CNC (Mill and Lathe) Control Software (NC) 0 06-14-2006 11:35 PM
file transfer axis overtravel Fadal 13 01-26-2006 09:55 PM
