Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 06-17-2009, 12:33 AM
kkungfu is on a distinguished road
Tailstock position recovery
Hi all
SL-60/3500 with MF-6 (16TB)
I've had one of my customers clear all his paramaters by accident trying to cancel the overtravel on boot up.
Ive managed to enter everything back in (NC an PC param) and set all the home positions again, so everything is working fine on that side, only thing now is the programable tow-along tailstock position.
Does anyone know how to set the actual position of the tailstock? At the moment, when I go into rapid and push the joint button, Z will only move to home position before the joint light becomes solid.
I asume it is one of PMC data param and have tried tracing it through the ladder to find which one, but is very time consuming.
I do recall years ago I had some trouble with doing the same thing and there was a procedure to set it a D param or keep relay or something.
Any help would be greatly appreciated.
tool changer recovery peakeng Daewoo/Doosan 2 03-06-2009 01:58 PM
Metal Recovery Technology zoulume Metal Finishing and Plating 1 12-12-2007 10:15 AM
coolant recovery vacuum? cncatj General Metal Working Machines 7 03-03-2007 06:44 PM
NSH TF Turbine Oil Recovery plant sinonsh22 Product Announcements & Manufacturer News 0 11-06-2006 12:52 AM
Sino-nsh Gas Engine Oil Recovery Secondary sinonsh22 Mechanical Calculations/Engineering Design 0 10-13-2006 01:02 AM
