| Mori lathes Discuss Mori lathes here. |
| Hey guys! Next week I need to thread 1" npt thread and I would like to do it in caps if possible, sooo if any of you experts can give me some advise on what to enter in the tapered thread menu I would much appreciate it! What has me stumped is the box labeled "STD.LNG.?????? the manual is real sketchy on the explanation for this.......it says, "Set the standard length of the tapered thread" (MM).... Well thats all fine and dandy but the next box ask's for thread length! I want to get the numbers as close as possible first time because I'm finishing the last thread really close to the chuck jaws and I'm a little nervous about this! T.I.A |
| Check machinery's handbook. There are a few different lengths given, one being effective thread length, which is the usable length, and then there is the runout length caused by cutting with a die, which is longer because those threads are useless in function. Then, you have to make allowance for the distance of the tool from the actual end of the work, to allow for spindle acceleration. There are several different things it could be. Ya know, you can trial run the program well away from the chuck without a workpiece to be wrecked
| Usually the ist length in Tapered threads relates to where the Smaller Diameter of the thread starts,I.E "0". Where you have also given the Crest Diameter.then you give actual length and Taper. If cutting up to shoulders turn off the runout. |
Thanks for that info, this thread is kinda old but I ended up handwriting the thread code and the parts came out great. If anybody would like to use my thread code P.M. me and I'll shoot you a copy! |
We call those a sfincter switch or a duck tail. Just two pieces of brass glued one to each ass cheek. Pucker panic button. |
| Where i'm from we call it the pucker plug. Although invasive, a real nice option to purchase with the machine... I hear they're working on pucker pants with a contactor in each back pocket but the repeatability isn't quite there yet... The benefit of the original pucker plug is that you don't mess yourself when you have a real big crash |
#10
| Voice Your Opinion On "POLYMER CONCRETE FRAME" Thread! | walter | Polls | 13 | 04-27-2012 07:19 PM |
| Index to "Epoxy-Granite machine bases" thread | walter | Epoxy Granite | 13 | 12-01-2011 10:45 PM |
| SpeedsCustom's "Set-Up-Shop" and project thread. | SpeedsCustom | Benchtop Machines | 1 | 11-10-2007 10:40 PM |
| Another " Moving a Tormach to a basement" Thread | Scott_M | Tormach PCNC | 10 | 03-30-2007 10:08 AM |
