Results 1 to 4 of 4
Thread: Mori SL-25 programing
    Feb 2012
    united states
    I am running an mori sl-25 with a yasnac I80L controll. I am getting an error "Faults in finished shape" with this program below once it gets to the G71. Thanks for any help
    N1(FACE WNMG431 .0156 RAD.)
    G50S2200
    G0T0101M8
    G96S1000M3
    X2.6Z0
    G1X-.03F.015
    G0G42X2.65Z.1
    G71P100Q101U.005W.01D1100F.015
    N100G1Z-1.35F.015
    X-.02
    X2.355F.004
    G3X2.45Z-1.39R.04
    G1X2.48Z-1.44F.003
    N101G0X2.65Z1.M9
    G70P100Q101
    G0G40X10.Z6.
    T0100
    M30
    May 2004
    Done.
    http://www.kirkcon.com/
    Registered dcoupar's Avatar
    Mar 2003
    Just curious... what does this part look like? Can you share a drawing?
    It looks to me like X has both decreasing and increasing diameters within the finish shape definition. If this is true, you need an R1 in the G71 block to specify a type II shape. Also, the shape definition looks "strange".
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    making it a type II canned cycle may help make it run but the profile seems very wrong to me.
    if this is an OD turning operation the tool moves like this....
    G0 X2.6 Z0 (rapid)
    G1 X-.03 F.015 (face cut)
    G0 X2.65 Z.1 (rapid)
    G1 Z-1.35 F.015 (feed to Z-1.35)
    X-.02 (feed to ~center)
    X2.355 F.004 (feed to X2.355)
    G3 X2.45 Z-1.39 R.04 (CCW radius to X2.45 Z-1.39)
    G1 X2.48 Z-1.44 F.003 (feed to X2.84 Z-1.44)
    when the tool is at Z-1.35 it then goes to X-0.02 which will part off the job when the G70 runs (using a WNMG insert!)
    assuming it even gets that far with the tool still in one piece. the roughing won't work with that profile.
  1. Okuma-Mori or Mori Dura
    By KKM in forum Okuma
    Last Post: 11-08-2010, 06:43 PM
  2. Newbie- Mori Seiki SL25MC...programing help
    By hemiturn in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 02-11-2010, 01:13 PM
  3. 0-M programing help please
    By venomgrrrl in forum Fanuc
    Last Post: 12-08-2007, 12:51 AM
  4. CNC programing
    By Fryzss in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 10-27-2007, 11:33 AM
  5. CAM programing
    By kenlambert in forum G-Code Programing
    Last Post: 02-03-2006, 01:03 AM
