Results 1 to 4 of 4
Thread: can I initiate a drip feed dnc with a macro from the controller?
    Jan 2006
    I am trying to figure out if I can initiate a dnc program from the controller to drip feed from pc\dnc software. I would like to identify the program from a macro in the machine.
    Any help would be appreciated.
    I would also like to set up a bar code reader to my controller, is this possible?
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    Not really sure what you're trying to do?
    I recall reading somewhere (in a Fanuc manual I think) that DNC of a macro is not possible.
    To do a DNC you have to be in TAPE mode but you cant call a macro from TAPE mode either
    You also cant run a program in memory and make it switch to DNC mode
    Jun 2012
    Ireland
    There are several ways of dealing with the barcode problem
    You can buy a system from someone like memex cimco or predator to dive a DNC system.
    Or you can write something to push the info into macro memory over FOCAS.
    I have being meaning to give g300 sieries codes a go to try and start DNC comms, full details are in the macro compiler manual.
    I also ned to try to push a program onto the data server and run that.
    Jun 2007
    Not that I know of. Had the same problem, ended up loading the program on memory expansion card (PCMCIA) then calling from the main as a sub.
  1. Drip Feed M (T) Plus Controller
    By scot1911 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-09-2012, 05:15 PM
  2. Drip feed CL200B and MSC803 controller
    By rkucbel1 in forum Mori lathes
    Last Post: 11-18-2010, 08:48 AM
  3. Newbie- Drip Feed to a Kiwa Colt Fanuc O-M controller
    By mud-usa in forum Fanuc
    Last Post: 05-05-2010, 08:43 AM
  4. Replies: 9
    Last Post: 04-28-2008, 01:10 PM
  5. confirguring OM controller for Drip feed
    By DerHammer in forum Fanuc
    Last Post: 08-15-2007, 10:51 PM
