| Mori lathes Discuss Mori lathes here. |
I am trying to machine a part that is 12.75" long. I need to chuck the part in both the main and sub spindals to do some milling and turning. The problem i am having is being able to rotate the spindal to a set angle to do milling. It wont let me just use head one spindal to rotate to a fixed angle. is there a way to syncronize the spindals so they will rotate together the same direction to a set angle. the machine i am using is a mori seiki sl153y. Any help would be greatly appreciated. Thank You Mike |
| you need to issue the sync spindle G/M code. it can depend on your specific control. M303/M304 - MAIN/SUB spindle active for spindle control commands M34 Dual synchronize spindles turning mode – Phase control C-axis chucks M35 Dual synchronize spindles turning mode – RPM speed only M36 Dual synchronize spindles turning mode – CANCEL most likely.... M303 M34 will do it. or something else. check your manual because Mori Seiki special G/M codes are usually different than Fanuc codes. The other option is just unclamp 2nd chuck then rotate the part while it is being held by 1st chuck then clamp 2nd chuck. i.e. M69 (sub spindle unclamp or whatever your code is) G00 C30.0 M68 (sub spindle clamp or whatever your code is) |
| Interest in Router Milling Heads for NM-200 and other machines. | cjjonesarmory | Novakon Systems | 11 | 07-10-2010 01:34 PM |
| Need Help!- Milling both sides of an part | chris123 | Benchtop Machines | 18 | 07-09-2010 01:21 AM |
| Newbie- Part holding and milling 3D part on 2.5D Mill? | john_t_h | General Metalwork Discussion | 6 | 03-15-2008 06:35 AM |
| Milling part #'s and logos? | mrg1216 | General CNC (Mill and Lathe) Control Software (NC) | 3 | 03-04-2008 05:17 PM |
| Heads Up - Article about building CNC Milling Machine | samualt | CNCzone Club House | 3 | 06-13-2005 02:43 PM |
