Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 12-16-2011, 07:53 PM
davesnd's Avatar
davesnd is on a distinguished road
Question 10TF option parameter locked
Hi all
I have happened to come across some handy information to expand my memory on my Mori seiki AL-2 lathe with a 10TF control on it. So I go into MDI and change setting 8000 bit 0 (PWE) to 1 and then go into service and select the parameter I want to change (inp. no) 9110 and it takes me to that parameter which is all so far so good. When I try and enter a new string of characters to update this parameter I get a little message in the bottom left corner of the screen saying 'parameter locked' . Crap! Any one know how to get past this?
Old 12-16-2011, 08:11 PM
underthetire is on a distinguished road
Can't enter them like that on a 10. You have to initialize the memory and do it ipl mode. Think you also need to re load all the parameters once you do it. Make sure you have all parameters backed up. You can brick things if you call more memory on option parameters than you have available bubble memory, and have to start from scratch.
Old 12-17-2011, 01:51 AM
yours_prabhat is on a distinguished road
Originally Posted by davesnd View Post
Hi all
Dear Sir ,
the parameter you are attempting to change is the option PARAM locked by the MTB (Machine tool Builder )So it gives the ALARM = PARAMETER LOCKED It contains lots of Information such as : param no 9110 (Fanuc 10 ) Details are as :9110
Bit0 = 00000001 (100 PROGRAMS) Bit1= (00000010 ) 200 PROGRAMS Bit 2) 0000100 400 PROGRAMS Bit 3 = ( 00001000 ) PPS 132FT , Bit4 = ( 00010000 ) PS262/200FT, Bit5= ( 00100000 ) GRAPHIC B, Bit6 = 01000000 ( SEMI-CONVERSATIONAL GRAPHICS )Bit 7= 10000000 = CONVERSATIONAL GRAPHICS
please feel free to communicate for any other information if required , regards prabhatmishra@gmx.com
Need Help!- How to unhiden option parameter 21i-MB greenery_fr Fanuc 11 07-04-2011 10:49 PM
Need Help!- Parameter for open and close chuck option! the mill kid Mazak, Mitsubishi, Mazatrol 2 08-13-2009 07:09 PM
T32 Option parameter O8 BIT 1 MTWOLFEL Mazak, Mitsubishi, Mazatrol 0 08-27-2008 09:29 AM
Cutter comp option parameter for 18 m ddfoe Fanuc 0 05-01-2007 08:02 AM
fanuc 9M option parameter YOO Fanuc 0 01-05-2007 05:22 AM
