| Mori lathes Discuss Mori lathes here. |
| Running 40" parts between the 2 spindles. Center section cut down from 4.3 to 2.875. 2.5 long x 4.0 diameter ends. I want to rough the center section with the head1 and the bottom turret. Head 1 plunge cutting at a 20 degree angle from X4.3 Z-5.5 to X2.875 Z-7.772. Then linear feed to 19.24. At the same time bottom turret plunge cuts from X4.3 Z-18.9 to X2.875 Z-19.22 then linear feed to Z-32.66. Problem is I can't get the two turrets to cut independantly. Different combinations of M314/M315 and G68/G69 don't work. I can get head1 to run it's operation but not bottom turret. I get a command prompt time out alarm. Can cycles on both programs. |
| you may need to add waiting codes to synchronize the turrets. usually waiting codes are M100 to M197 also possibly need other M-codes like M303/M304 - MAIN/SUB spindle active for spindle control commands M34 Dual synchronize spindles turning mode – Phase control C-axis chucks M35 Dual synchronize spindles turning mode – RPM speed only M36 Dual synchronize spindles turning mode – CANCEL I don't know what M314/M315 is. If you post the full program we may be able to help more..... Last edited by fordav11; 10-21-2011 at 04:17 AM. |
| oh wait. you are telling the machine to do balance cutting (G68) but the two process paths you want to cut are completely separate so it is not a balance cutting operation. try removing the G68 and let both programs run by themselves. you may need to add a waiting code at the start of the cycle so they are both positioned at the start diameter and ready to go and another wait code at the end of the cycle and leave the tool at the same X position until the other head has completed then move both turrets away together. i.e. Code: program 1 program 2 --------- --------- G0 X4.3 Z-5.5 G0 X4.3 Z-18.9 M100 M100 G71 P10 Q11 etc G71 P10 Q11 etc N10 N10 ...... ....... N11 N11 M101 M101 G0 X300. Z300. G0 X300. Z300. Last edited by fordav11; 10-21-2011 at 04:51 AM. |
| M314/315 is feed sync on and off. M303 and M35 are used. I've tried wait codes and that didn't work. I have been able to get head1 and turret 2 to start at same time but t2 waits at end of cut for h1 to finish that cut and both start at same time for next cut. Not reducing cycle time that way. |
#10
| Haven't tried long hand. There are several proven programs, all with canned cycles. If I can make it work with cycles my life is easier. I work for a large corporation with a programming dept. I can't get much help from them. The don't think the proven programs should be changed. I have been on this 9 axis Mori (my first) for 2 months and I think I know more than them. And I'm learning new **** everyday. I miss the Integrex I ran. |
#11
| "I have been able to get head1 and turret 2 to start at same time but t2 waits at end of cut for h1 to finish that cut and both start at same time for next cut. Not reducing cycle time that way." Is there an interference problem that has made you write one tool with a longer path than the other? I would make them the same length so they start and finish at the same time. Why can't you use a normal balance cut process? Maybe try starting at each end and work towards the middle? |
| Need Help!- NT4250 Tool Pre-Setter alarm | dimatec | Mori lathes | 2 | 09-07-2010 12:20 PM |
