| Mori lathes Discuss Mori lathes here. |
| hi all- two questions i hope you can help get through my head ![]() one i think may be more mori sl-2h specific the other, perhaps so as well... 1. i have a piece of code where i've stated G28 X0. Z0. when executed from zero return, the turret moves in the X-(turret goes up) and Z+(turret goes away from spindle). given my newfound fear of crashes, i've feed stopped the movement before it hits the hard limits. is this G28 supposed to do this? when the turret is in the safe travel zone, and G28 appears, it does go back to zero return at X0.Z0 which makes sense. what am i doing wrong here? 2. G50 is completely escaping me. i've read the online articles, my cnc programming book, and i generally understand the concept, but can't seem to wrap my head around how to employ this given in pages 80-83 in my mori sl-2 manual (B-121601-E). i guess my main question is, what in fact are my G50 values? how do i know what my "dimensions of cutting tool starting point (programmed G50)" value is? thanks! david
__________________ Mini-Mill Kits and Plans - http://www.fignoggle.com Sieg X3 and Super X3 Mill Information - http://www.superx3.com |
| G28 is return to first reference return position. I usually use G0G28U0W0 on a lathe. Seen some horrific crashes from people not specifying an incremental move like G91 or the U and W. In fact, at my old job, a applications engineer was teaching a customer how to run his BRAND NEW Mori horizontal. Hadn't even cut a chip yet. Well, it was look how fast this thing is. Boy was it, he forgot the G91 command with the G28, X and Y bounced right off the pallet. Bent the spindle, destroyed the X axis linear guides. At that kind of rapid speed, things to go very wrong with steel to steel contact. |
| I'll give this a shot although I'm a little rusty on lathes. G28 is a "Zero return" command. The X & Z values are an intermediate move location and tell which axis are to be moved home. As you have written, the first move would be to absolute X0Z0 (assuming you are currently in G90 mode). Usually this code is: G28 G91 X0 Z0 G90 if you want no intermediate move before the zero return. The zero return position is usually at the travel limit and sometimes called "home" or "reference" or "grid" position. I've done a G28 G91 X1. Z0 to retract in X then move to "home" Usually this is used for an ultra safe tool index position or at the end of the program. I think you can use G30 (don't take my word for it, check your manual) for a user defined return or safe index position. The G50 is a work coordinate shift and is the distance from home to part origin + any tool offsets. So if your tools were set to the chuck face and centerline, and your workpiece zero were 6.000 off the chuck face you would have a G50 Z6.000 at the beginning of the program. |
| CNC mill questions - thrust bearings, leadscrew mounting, general questions | tonofsteel | DIY-CNC Router Table Machines | 8 | 02-03-2012 03:42 PM |
| Brass vs Aluminium Vs Steel, questions, questions and questions... | alexccmeister | General Metal Working Machines | 25 | 08-15-2011 12:40 PM |
| Newbie- Questions | regretfulflyer | Hobby Discussion | 0 | 05-23-2011 05:52 PM |
| 100% new, a few questions | theclive | General Metal Working Machines | 1 | 03-08-2007 12:52 AM |
| Few questions | fzmn321 | Hobbycnc (Products) | 4 | 05-08-2006 04:04 PM |
