Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 08-24-2011, 02:48 AM
aidenkim is on a distinguished road
Thumbs up Battery change and initializing position _ NL series
I need help ~
i have a NL series machine and it's battery for NC,SERVO parts was down,
so i changed it and resetting the absolute position (X,Y,Z) yesterday
however, when I try to set for 'T' axis today, the problem is that i can not change the status of ZERO POINT SET to 'VALID'
when I try to change it to 'VALID', the message 'zero point set is already done' is issued, even T axis doesn't set before
please let me know the way to change ZERO POINT SET to 'VALID'
or the way to set T axis ~
Old 08-25-2011, 04:24 PM
fordav11's Avatar
fordav11 is on a distinguished road
if the battery died and you lost all of the parameters you're going to need a Fanuc service man to visit you to re-install everything.
That's all part of the protection on Fanuc systems and why there are so many undocumented parameters. If you have option boards installed like 4th Axis etc then there's no way to get it working without having the secret option parameters. If you don't have a back-up there's no way to fix it yourself.
If you have the parameter manual you should be able to re-set most of it and get it mostly working but it'll never be 100% without a Fanuc service guy to do the secret stuff.
Old 08-26-2011, 08:28 AM
dbstream is on a distinguished road
This machine comes with Mitsubishi NC. I think best you contact local rep to resolve your turret (T) zeroing issue.
Tags
nl; zero point set
Need Help!- Change Battery on Maho 600E, Phillips 432 Konrad Deckel, Maho, Aciera, Abene Mills 4 08-15-2010 10:28 PM
Problem- Battery change OSP7000L bengt65 Okuma 4 07-01-2010 08:59 AM
mtm tool change position double a-ron GibbsCAM 2 01-24-2010 11:29 AM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
Help! Dead Series 1 R2E3 battery, need jumper cable? Bill Gillen Bridgeport and Hardinge Mills 4 10-12-2006 05:24 PM
