Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 08-19-2011, 07:11 AM
JerryF is on a distinguished road
Problem with threading cycles
We have an old Mori ZL-250 that we typically use just for simple parts that are turned, drilled, bored, etc. We have to do a small run of a part that is OD threaded and when we try to use any of the threading cycles we get a 490 alarm which is related to the spindle. This happens in G92, G76 and G32. All other G commands work fine. Any ideas about where to look? Thanks in advnace for any help you can provide.
Old 08-19-2011, 08:57 AM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
What type of Control does it have?
http://www.cncalarms.com/
Old 08-19-2011, 10:33 AM
It's a fanuc 18i. We think it might be the spindle speed sensor causing the problem.
Old 08-19-2011, 11:15 AM
It may be an easy fix if its the spindle encoder.
Then it may not be.....
Hope Not!
Check all the connections, unplug/plug back in after cleaning.
Make sure the belt is not skipping teeth on the spindle splines or the encoder pulley, etc.....
Also do the rpm's match what you programmed on the screen?
Let me know what yall find out.
http://www.cnczone.com/forums/fanuc/...lem_-_rpm.html
Tags
threading cycles
Just IN- G78 Threading Problem bigmantate Europe Club House 0 09-07-2010 01:10 AM
Need Help!- G76 Threading problem bmlw Fanuc 7 02-26-2010 04:42 AM
threading problem girishnadkarni Fanuc 6 08-29-2008 05:22 PM
Ultimax II Canned Drill Cycles Problem badboy HURCO 2 06-11-2008 12:40 AM
canned cycles problem joachim Fanuc 15 04-01-2008 12:01 AM
