Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 08-11-2011, 07:52 AM
Amstaff is on a distinguished road
NZ 2000
Hi guys!
Anyone who has a clue why I get the alarm code "Interference in G41/G42", when using this program:
GO T1313
G54
G99
G96S210M03
G0 X126. Z10. M08
G0 Z2.
G41 G1 X124.1 Z0 F0.2
G1 X122. ,R-1.0
G1 Z-5.3 ( This is where the alarm occurs))
G1 X121.1
G1 X120.5 Z-5.473 F0.1
G1 X117.985 Z-8.928 F0.2
G1 Z-28.37 F0.3
G1 X120.5 Z-32.027 F0.2
G1 X121.1 Z-32.427
G04 X1.0
G1 Z-34.3
G0 X116.
G40 G0 U-1.0 Z10. M09
G0 G28 U0
G53 Z-350.0
PS0041 INTERFERENCE IN G41/G42
I´m using the exact same code in a NL 3000 and it works just fine there.
Old 08-18-2011, 10:45 PM
zooloader's Avatar
zooloader is on a distinguished road
I'm pretty new to Mori and don't understand what this is doing "G1 X122. ,R-1.0", but I'll assume it's all good.
If doing a process in SP1 with TRT1 and using G41, the same process in SP2 with TRT2 is G42.
Old 08-21-2011, 04:12 PM
fordav11's Avatar
fordav11 is on a distinguished road
try doing it in a more standard way.....
G0 X124.0 Z2.0 M08
G41 G1 Z0 F0.2
G2 X122.0 Z-1.0 R1.0
G1 Z-5.3
etc
Old 09-16-2011, 01:34 AM
blue1's Avatar
blue1 is on a distinguished road
Hello zooloader i use a mori ZT1500 and G41 and G42 are clockwise and anti clockwise interpolation irrespective of the turret assigned the command. Most of the M codes are spindle one or spindle two specific as used for spindle clamping and chucking operations,eg. chuck closed on sp1 =M10 and the same command for sp2 =M210. Also i am fairly new to cnc machinery and have not been fortunate enough to have access to any sort of knowledge base in this area, causing a lot frustration early on. The majority of what know has been extracted from the users manual and i wish i had found this forum when i first started, it would have saved a lot of heartache and crashes! I hope i have passed on correct information for you. Ps im a bit further up the coast in Mackay have a great day.
NL 2000 positiverake Mori lathes 3 06-02-2009 10:33 PM
ge 2000 error JNFSWE General CNC (Mill and Lathe) Control Software (NC) 7 03-12-2009 05:18 PM
gt-2000 CAD models Chubs Jet Engines and Ram Jets 6 05-11-2007 11:42 PM
2000 RPM new TL-1 xyzcnc Haas Mills 2 04-19-2006 10:10 AM
