Results 1 to 5 of 5
Thread: Mori NL 3000 not enough memory
    Jul 2011
    I have a Mori NL 3000 with live tooling. I have a large program the I cant load in the machine memory. How or can you run a program from the USB flash drive?
    Feb 2009
    I dont think you can run it from USB, but you can put quite large programs in to the mapps memory and run from there. Contact your local Mori guys, they should be able to get you the how to. it is really quite easy. Think std memory on the mapps was 10MB.
    Jul 2011
    I talked to Mori and the guy said i needed to load the program in the user area and run it from there but when i load the program it tries to put it in NC memory and it cant because its too big. He also said i needed to switch to tape. i still cant figure it out. He said it was in the book but that's like finding a needle in a hay stack.
    Feb 2009
    In one of the setting pages on Mapps, it says NC memory or Maps I believe on the DNC line. it's pretty visible when you see it. Tape mode is just the button next to auto/edit/mdi on the op panel. We use it all the time here (not me, I only really fix them) but we also bought the 1 GB upgrade on the mapps machines. The guys say it runs just like it does when loading it to the machine memory. I also don't think they had to be in tape mode, I'll run out there and see. Do you have Maps 3 (dark gray bezel around the screen) or Maps 4 ( ivory bezel )?
    Jul 2011
    ours is dark gray. I see what you are talking about on the screen but how do you switch it so you can run the program from the user area. The first problem is when you load a program it loads it into the NC memory first. I need to know how to load it into the user area first and then make the switch and run it from there.
    1. Okuma-Mori or Mori Dura
      By KKM in forum Okuma
      Last Post: 11-08-2010, 06:43 PM
    2. Need Help!- Memory alarm on Mori seiki lathe
      By hectorbach in forum Mori lathes
      Last Post: 01-05-2010, 07:04 PM
    3. Mori NV5000, program directory (available memory)
      By teal854t in forum Mori Mills
      Last Post: 07-31-2009, 09:57 AM
    4. Mori seiki MV40E memory card problem
      By v.sundermoorthy in forum Mori Mills
      Last Post: 04-20-2009, 03:35 PM
    5. mori nl 3000 over travel
      By gcutter6 in forum Mori lathes
      Last Post: 03-12-2008, 03:28 PM
