Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 05-19-2011, 12:44 PM
Fear is on a distinguished road
Unhappy CL-150 Unreadable EMG message
Finally able to hook up the hydraulic pump but now when we start up the machine this error appears and we are unable to clamp/unclamp the chuck or move the turret, I switched up the hydraulic lines to make sure they where in the right place as far as I know. Any info is greatly appreciated.
I took a picture of the error since I cant type it out.
Old 05-27-2011, 10:02 AM
iNUC is on a distinguished road
It seems that you losed all parameter. Need to input them back.
Good luck.
Old 05-27-2011, 12:47 PM
Good luck.
Checked all the parameters
Old 06-07-2011, 11:24 AM
underthetire is on a distinguished road
It's just a Estop alarm. Check chip conveyor, all buttons, and overtravel conditions. Did the machine have a barfeeder on it?
Old 06-09-2011, 09:45 PM
DryRun is on a distinguished road
no hydraulic psi check that p and t on lines are right , check pump rotation (phase)
Old 06-09-2011, 09:49 PM
check that pump is building psi (correct phase UVW) are port and return lines Correct?
Tags
cl-150, emg, error code, unreadable
Need Help!- EMG message!!! RACooper_299 Fanuc 5 11-12-2009 10:43 PM
E.009 Message Help toby51 Machine Problems, Solutions , Wireless DNC, serial port 0 01-16-2008 01:51 PM
E.009 Message Help toby51 General CNC (Mill and Lathe) Control Software (NC) 0 01-16-2008 03:45 AM
HOw can I tell if PC-2 is getting message from PC scheek Mach Software (ArtSoft software) 1 04-13-2006 09:36 PM
Why can't I put **********.com in message? samualt Forum Questions or Problems 12 09-12-2004 09:52 AM
