Results 1 to 8 of 8
Thread: Lock pin in alarm in Mori seiki SL-25
    Registered Bilic's Avatar
    Aug 2010
    Anyone knows a code to unlock the pin at the back of the spindle of Mori Seiki SL-25.
    Feb 2009
    Never seen a lock pin on a SL25 spindle. Is this a live tool machine? Error code number? What control ?
    Aug 2010
    Not Lock pin in
    This is what it says on the screen :
    "operators message"
    EX0980 Not Lock Pin In
    and at the back of the machine where the spindle is there is a slot and small hydraulic device extracted pin in to the slot of a spindle an preventing it to turn.(with the alarm message as above)
    Jan 2009
    Sri Lanka
    brother i dont know anything about your question. but l like to know how to operate Mori saki SL 35, could you help me?
    Jul 2009
    MEXICO
    Does your machine has tailstock?
    On those Models you have to align tailstock with Z axis in order to move.
    But if Limit switch inside TS is not made detecting TS Clamp
    perhaps the alarm you are having.
    Or as you say if this system is on Spindle you must have a sensor to detect and you can make it (with piece of metal) and see if alarms resets.
    Robby
    Mar 2008
    SGP
    Most likely a SL-25M machine with indexable C-axis. Try adjusting the grid shift value till lock pin seat.
    Feb 2009
    Quote Originally Posted by Bilic View Post
    "operators message"
    Ok, so you have a very early SL25M. If you haven't got it by now, post back. It's just either the lock pin is not engaging all the way, or the prox switch is out. If it's not moving I would check in the prints. There is a Bestac relay card that controls the solenoid for the pin. That machine should have 3 of them, and they can be swapped around to diagnose. If the Bestac is bad, you can get replacement relays from Digi-Key if you are handy with soldering.
    Aug 2007
    Thailand
    Post Mori SL25M Fanuc 10TF
    Hello,
    I need help my machine lose the parameter and PC rom.Do you have the parameter and electric diagram of this machine.
    1. Mori-Seiki SL-0 / Yasnac LX1 Alarm Code 332 Help!?!
      By larrynsr in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 01-11-2013, 03:46 PM
    2. Need Help!- Mori Seiki Fanuc 6M ALARM ERRORS
      By HouTX in forum Fanuc
      Last Post: 12-02-2010, 06:55 AM
    3. SERVO ALARM 401 REPEATING IN MORI SEIKI
      By CHANDRU in forum Mori lathes
      Last Post: 12-02-2010, 06:36 AM
    4. Mori Seiki Fanuc O-T Alarm 100 p/s
      By hrhoward in forum Mori lathes
      Last Post: 10-15-2010, 02:33 PM
    5. Need Help!- Memory alarm on Mori seiki lathe
      By hectorbach in forum Mori lathes
      Last Post: 01-05-2010, 07:04 PM
